internationalization [message #901495] |
Mon, 13 August 2012 07:26 |
Chris B. Messages: 37 Registered: November 2011 |
Member |
Hi everyone,
i'm currently dealing with i18n in GMF and i need to know whether
it is possible to externalize the strings of the labels (name and text attributes) in gmfgraph into the message.properties file. If so, could anybody give me some instructions on how this can be done?
Chris
[Updated on: Mon, 13 August 2012 08:32] Report message to a moderator
Re: internationalization [message #901568 is a reply to message #901495] |
Mon, 13 August 2012 13:09 |
Member |
Maybe I've expressed myself incorrectly. The text/name attributes for the label in the properties view should be variable. For example, I've seen in the gmfgen file a property 'content extension name' which has the value '%navigatorContentName'. The percent sign indicates that it's a variable name declared in the plugin.properties, e.g. 'navigatorContentName=*.mmd diagram contents'. However, I want GMF to extract the label strings as variables into the generated messages.properties file in the diagram package but the percent syntax doesn't work for gmfgraph figures.
[Updated on: Mon, 13 August 2012 13:10] Report message to a moderator
FUDForum. Page generated in 0.03554 seconds
