Home » Archived » Lua Development Tools » LDT and Lua Inspect
LDT and Lua Inspect [message #901446] Sun, 12 August 2012 09:10 Go to next message
Hi Koneki developers,
I'm going to develop Lua support for other IDE (Qt Creator), and I'd like to ask you a couple of questions:
1) Are you aware of Lua Inspect [1]?
2) Why don't you use it in LDT?
Thanks in advance.
[1] lua-users.org/wiki/LuaInspect
Re: LDT and Lua Inspect [message #901721 is a reply to message #901446] Tue, 14 August 2012 06:25 Go to previous message
We're aware of LuaInspect indeed, but it doesn't really fit with LDT's needs.
First, it should be noted that a large part of LuaInspect is actually Metalua's parser, which is also used by LDT.
Beyond parsing, LuaInspect essentially performs variables scope analysis, and reports it as pretty-printed HTML renderings of the original source files (it also supports CSV dumps for editor integration). Its understanding of datatypes is limited, by design: it tries to keep track of functions' number of arguments, plus some simple guesses when native Lua types are used. But it won't keep track of non-native datatypes, and won't take hints when it's lost. Such a level of detail would be overkill to generate some HTML and pinpoint undeclared globals; but without it, you can't realistically hope to provide state-of-the-art autocomplete and refactoring services in an IDE.
LDT is built around a clearly defined datatype model, and supports a DSL within the comments which allows to specify type information when it can't be guessed, or when it's guessed wrong. You can't shoehorn such a model into code that was designed for a very different purpose. Besides, if you ignore parsing (done by Metalua) and HTML rendering (which we don't care about), most of the analysis performed by LuaInspect is easily expressed as Metalua treequery requests.
Previous Topic:Code completion does not work with global variables
Next Topic:No Outline Information for Lua Files
Current Time: Thu Nov 06 20:51:33 EST 2025
Powered by FUDForum. Page generated in 0.04594 seconds
