Home » Archived » BIRT » Data cubes and performance issues(How can I filter the datacube to avoid computing aggregates which will never be used)
Data cubes and performance issues [message #901303] |
Fri, 10 August 2012 16:46 |
ing omini Messages: 26 Registered: March 2012 |
I have a perfomance issue with a BIRT report (Eclipse BIRT Designer Version 2.3.2.r232_20090202) which is putting a crosstab for each group of a list.
I cannot upload the original report because it contains sensitive data, but the following conceptual example is very similar:
1) I have a "control" dataset DS_COU containing:
"country","filter_column"
This dataset is parametric on "filter column" and only a few countries will be selected.
2) Another dataset DS_POPUL used by datacube contains:
"country","city","genre"(whose values are M or F);"population"
3) A datacube is built over DS_POPUL
3) the report will iterate over a list of countries returned by DS_COU dataset (NOT ALL countries but only a small subset!)
4) for each item of the list, a crosstab must be created using the cube built over DS_POPUL (but also other datasets will be used for other purposes)
Example:
SPAIN
CITY, MALE, FEMALE
Madrid, 10.000, 12.000
Barcelona, 8.000, 9.000
FRANCE
CITY, MALE, FEMALE
Paris, 5.000, 8.000
Please note that:
- my datacube is built upon a large dataset (millions of rows), but at the execution time only a small subset of it will be used.
- computing the aggregation for all countries cannot be done for performance issues.
- the datacube query would be very fast if filtered only for the current item of country list
Correct me if I am wrong. The sequence is:
1) by checking active sessions on Oracle, it seems that the datacube is built at the beginning, before iterating on the list, and that it's built over all possible combinations
2) crosstabs can be instantiated basing on the datacube
3) dynamic filters (basing, for example, on the current "country") can be applied
Now, my question is: is it possible to build the datacube only for the countries contained in the list (that is, on the result of parametric dataset DS_COU)?
Or in alternative, to build it N times, for each country?
Thanks in advance for helping me!
Re: Data cubes and performance issues [message #901622 is a reply to message #901303] |
Mon, 13 August 2012 17:14 |
If your country select list is a parameter why not cull your DS_POPUL by
using the parameter in a where clause (Let db filter it, it will be
faster). Look at the attached example that filters a dataset based on
parameter values and modifies the query in the beforeOpen script of the
dataset. If you build your cube off of this, it should be much quicker.
Then in your grouping of crosstabs you can filter the crosstab based
on the a particular country.
Jason
On 8/10/2012 12:46 PM, ing omini wrote:
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> Correct me if I am wrong. The sequence is: 1) by checking active
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901623 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901624 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901625 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901626 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901627 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901628 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901630 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901632 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Re: Data cubes and performance issues [message #901633 is a reply to message #901303] |
Jason
> of a list.
> will be selected.
> purposes)
> Example:
> SPAIN
> CITY, MALE, FEMALE
> FRANCE
> CITY, MALE, FEMALE
> Paris, 5.000, 8.000
> Please note that:
> performance issues.
> be applied
> dataset DS_COU)?
Current Time: Sat Sep 21 03:08:22 GMT 2024
Powered by FUDForum. Page generated in 0.04894 seconds
