Home » Eclipse Projects » Remote Application Platform (RAP) » RWT Dev Setup
RWT Dev Setup [message #901208] Fri, 10 August 2012 06:38 Go to next message
Can someone tell a beginner how to set up the RWT 1.5 bundle from git to run with a modified javascript? It would also be great to learn how the js gets minimized.
I set
-Dorg.eclipse.rwt.enableUITests=true
-Dorg.eclipse.rwt.clientLibraryVariant=DEBUG
But it pulls only the client.js, this is all I can see. Do I need another parameter to the servlet to make this work?
Re: RWT Dev Setup [message #901255 is a reply to message #901208] Fri, 10 August 2012 09:56 Go to previous messageGo to next message
Hi Thomas,
to compress the JS use Client Builder from here:
https://github.com/eclipsesource/rap-clientbuilder
HTH,
Ivan
> I set
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RWT Dev Setup [message #901344 is a reply to message #901255] Sat, 11 August 2012 00:25 Go to previous messageGo to next message
The project you mentioned refers to the old qx07 bundle and doesn't work for me.
Isn't there any up to date documentation how to set up a rwt dev/debug environment?
Re: RWT Dev Setup [message #901345 is a reply to message #901344] Sat, 11 August 2012 00:29 Go to previous messageGo to next message
Thomas,
only the documentation is not up to date. I'm using this project in my
daily work with RAP 1.5 and 2.0. Use master branch for 1.5 and 2.0 and
1.4-maintenance for RAP 1.4.
Best,
Ivan
> work for me.
> environment?
Ivan Furnadjiev
Re: RWT Dev Setup [message #901346 is a reply to message #901345] Sat, 11 August 2012 00:43 Go to previous message
I guess you meant https://github.com/ralfstx/rap-clientbuilder for sure
Previous Topic:IE9 does not display png images when SSL [SOLVED]
Next Topic:Redirect to https
Current Time: Sat Oct 25 18:40:50 EDT 2025
Powered by FUDForum. Page generated in 0.05559 seconds
