Re: TreeNatTableExample - single selection on expand/collapse image doesn't work [message #909733 is a reply to message #903975] |
Fri, 07 September 2012 17:01 |
I am also having a problem with single-click expand and the TreeGridExample. It appears that DefaultTreeLayerConfiguration() has been removed on head, and the bindings moved to TreeLayer. This change is working fine for the checkbox example, but not for TreeGridExample. From debugging, it appears that the code is matching to MouseEditAction via BodyCellEditorMouseEventMatcher instead of TreeExpandCollapseAction via CellPainterMouseEventMatcher. As an experiment, I modified the code in UiBindingRegistry.getMouseEventAction() so that it would find all actions. In this case both the MouseEditAction and the TreeExpandCollapseAction are found. For the checkbox example, only the one correct action is found.
Re: TreeNatTableExample - single selection on expand/collapse image doesn't work [message #913026 is a reply to message #910657] |
Fri, 14 September 2012 16:16 |
Single click selection (i.e., not expand/collapse) in the tree examples is not working either. Please note that at first I thought this was intermittent, but then I noticed that single click-drag works just fine. This means that if you don't keep your mouse perfectly still while clicking, it will look like it is working.
This doesn't appear to be the same problem as for tree expand/collapse. I modified UIBindingRegistry.getMouseEventAction() again as I described below, but this time I didn't see that one mouse action was hiding the other.
Tom
FUDForum. Page generated in 0.04778 seconds
