Re: EMF Compare - comparision throough emf compare failed [compare] [message #900932 is a reply to message #900805] |
Thu, 09 August 2012 07:09 |
Exceptions such as these really happen when EMF (and not Compare) cannot find the metamodel of your models. When you try and open your "*fm" models in their regular editor (or through right-click > open with > sample Ecore reflective editor), you will get that same error logged. The problem is that the metamodel of your "fm" files is not accessible to your current Eclipse. It needs to be installed or located in a previous workspace (put the metamodel in a workspace, then use Run > Run As > Eclipse Application. You will be a new Eclipse with an empty workspace, but from that particular Eclipse, your metamodel will be accessible). When this is done correctly, you will be able to open your models in their generated editor and/or compare them.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.03209 seconds
