Home » Archived » BIRT » Setting the value of the value of the page variable to the value of the computed column in dataset
Setting the value of the value of the page variable to the value of the computed column in dataset [message #900798] Wed, 08 August 2012 10:03 Go to next message
I want to set the value of a page variable to the value of the computed column on the onFetch script of the dataset.But it doesnt seeme to work.
Can you help me on that?
Re: Setting the value of the value of the page variable to the value of the computed column in datas [message #900833 is a reply to message #900798] Wed, 08 August 2012 12:33 Go to previous message
Rupal,
The onFetch is not a good location to set a page variable as all the
onFetch events may be call prior to creating the first page. Can you
give some more detail on what you are trying to do and we can propose a
different method of doing it.
Jason
Previous Topic:Order by clause
Next Topic:CDT Custom build Option to be added in Projects Context Menu and run for Both MBS and Standard Make
Current Time: Wed Oct 29 11:51:15 EDT 2025
Powered by FUDForum. Page generated in 0.03075 seconds
