Why hyperlink is broken when corresponding Xtext resource is moved? [message #900327] |
Mon, 06 August 2012 09:57 |
Hyperlinks among Xtext resources are broken when a given resource is moved. Have you ever encountered a similar problem ? Let me explain the scenario :
I start my 2nd Eclipse instance and I clean my workspace. My Xtext project includes the resources R1 and R2. Resource R2 is referred by resource R1 via an element E1. If I click on E1 then R1 is opened. Suppose R2 is moved to other folder. I clean my workspace again. When I click on E1 I get the error "Resource R2 does not exist". The only way to get the hyperlink working is to restart my Eclipse instance.
The Xtext version I use is 2.2.1. The mwe2 file contains the fragment ImportNamespacesScopingFragment and I implement my own ScopeProvider which extends AbstractDeclarativeScopeProvider.
Thank you for your help.
Kelly G.
FUDForum. Page generated in 0.02587 seconds
