Home » Modeling » UML2 » Possible Children
Possible Children [message #900247] Mon, 06 August 2012 03:25 Go to next message
I want to create an application where you see the UML model tree and can open a context menu and add children to a certain element (similar to the UML model editor).
How can I find out the possible children of an element?
selectedElement.eClass().... and now? Smile
Tex
Re: Possible Children [message #900262 is a reply to message #900247] Mon, 06 August 2012 04:50 Go to previous messageGo to next message
If you think about your question you may find an answer...
What do you mean by children?
Perhaps: How do I find all classes that conform to the type of some feature?
Finding all derived classes is not possible until you supply all models
in which those classes exist. Once the models and EPackages are loaded
you can do a naive search of all EPackage.eClassifiers or use ESuperAdapter.
Ed Willink
On 06/08/2012 08:25, Tex Iano wrote:
> selectedElement.eClass().... and now? :)
> Tex
Re: Possible Children [message #900271 is a reply to message #900262] Mon, 06 August 2012 05:42 Go to previous messageGo to next message
Ok, I did not describe pretty well what I am looking for.
For example: I have selected a UML Package. Then within my menu I want to have:
- PackagedElement
-> Class
-> Interface
-> etc.
- Profile Application
and so on.
So obviously I can use getEAllContainments for this right? Or should I work using Features?
When using getEAllContainments I get Profile Application, Packaged Element etc. as references. Is this the right way? But then: How can I get all Packaged Elements, i.e. Class Interface etc.?
reference.eClass().getESuperTypes() does not return those.
Tex
Re: Possible Children [message #900275 is a reply to message #900271] Mon, 06 August 2012 05:55 Go to previous messageGo to next message
I've really no idea what you want.
You think you know what you want, so you jump straight to a solution,
and find that it doesn't work.
I tried to encourage you to think clearly about the navigation that you
are attempting to perform. Once you understand the model navigation
steps that are needed, you may succeed in configuring your tooling to
achieve it.
Ed Willink
> to have:
> - PackagedElement
> -> Class
> -> Interface
> -> etc.
> and so on.
> Tex
Re: Possible Children [message #900447 is a reply to message #900275] Tue, 07 August 2012 03:15 Go to previous messageGo to next message
I think he wants something similar to ReflectiveItemProvider's
collectNewChildDescriptors. Likely just reusing it would be most direct.
On 06/08/2012 11:55 AM, Ed Willink wrote:
> Hi
> you are attempting to perform. Once you understand the model
> navigation steps that are needed, you may succeed in configuring your
> tooling to achieve it.
> Regards
> Ed Willink
>> want to have:
>> - PackagedElement
>> -> Class
>> -> Interface
>> -> etc.
>> and so on.
>> Regards,
>> Tex
Re: Possible Children [message #900596 is a reply to message #900447] Tue, 07 August 2012 12:43 Go to previous messageGo to next message
ok sorry for all that confusion. I will give you an example:
I have a UML package. Now I want to know which elements I can add as child (similar to a typical UML tool). I.e. I want to know that I can add a Class or an Interface to the packagedElements of a Package etc.
I found out that I can use the containments for that purpose:
		for (EReference ref : element.eClass().getEAllContainments()) {
This returns the reference lists, such as packagedElement or ownedComment. Now I want to know, which elements, i.e. EClasses I can add to these lists.
for (EClassifier classifier : UMLPackage.eINSTANCE.getEClassifiers()) {
			if (!(classifier instanceof EClass)) {
				continue;
			EClass c = (EClass)classifier;
			if (c.isAbstract()) continue;
                        if (ref.getEReferenceType().isSuperTypeOf(c)) {
                           System.out.println("This EClass can be added to the list");
Is this the right way to do this? Now I want to create an instance of this EClass and add it to a certain reference list. And here I don't know how.
But is the rest ok? Never heard about collectNewChildDescriptors etc. But I think my solution looks not too bad doesn't it? Smile
Tex
Re: Possible Children [message #900659 is a reply to message #900596] Wed, 08 August 2012 01:06 Go to previous messageGo to next message
Try: eClass.getEPackage().getEFactoryInstance().create(eClass)
Ed Willink
On 07/08/2012 17:43, Tex Iano wrote:
> add to these lists.
> continue;
> to the list");
> know how.
> But I think my solution looks not too bad doesn't it? :)
> Tex
Re: Possible Children [message #900686 is a reply to message #900659] Wed, 08 August 2012 03:42 Go to previous messageGo to next message
ok thanks, that works. But the created instance is not yet part of the superior element. I.e. for example I create a class and want to add it to the packagedElements list of a UML package:
//This returns an instance of the packagedElement, for example Class
EObject e = umlPackage.eClass().getEPackage().getEFactoryInstance().create(c);
umlPackage.eContents().add(e);
But this does not seem to work. I think that I have to consider the reference lists right? So I have to use the references I requested by using the containments list. But don't know how.
Tex
Re: Possible Children [message #900706 is a reply to message #900686] Wed, 08 August 2012 04:48 Go to previous messageGo to next message
Btw: collectNewChildDescriptors seems to be exactly what I am looking for. But is there a good tutorial/example? Google was not really helpful.
Tex
Re: Possible Children [message #900723 is a reply to message #900706] Wed, 08 August 2012 05:59 Go to previous messageGo to next message
Buy the EMF book by Ed Merks wet al. See the EMF Project page.
Ed Willink
> Tex
Re: Possible Children [message #900770 is a reply to message #900723] Wed, 08 August 2012 08:37 Go to previous message
Ok thanks. I already found this out:
EditingDomain ed = AdapterFactoryEditingDomain.getEditingDomainFor(currentElement);
Collection c = ed.getNewChildDescriptors(currentElement, null);
This returns a generic collection. Looks not bad Smile
Previous Topic:Unique element ID before saving
Next Topic:Insert Package Content into another Package
Current Time: Fri Oct 31 19:13:58 EDT 2025
Powered by FUDForum. Page generated in 0.05012 seconds
