Re: Eclipse - extract data from XML file on a Server [message #900220 is a reply to message #900212] |
Sun, 05 August 2012 17:16 |
On 08/05/2012 10:25 AM, alexandra123 leech wrote:
> Hello,
> I am looking for some guidance here , hopefully someone can help.
> Basically I have eclipse installed. I have a web page with XML data. I
> want to retrieve the data from the XML and load it into a database table.
> The database table has been created.
> I have created a java project that connects to the web page and I have
> created a sax parser that reads in the data with getters and setters.
> I was told that to bring this data into the database I should use a JPA
> project.
> I have created a JPA project and associated the appropriate database
> connection and table to the project.
> How do I sync up getting the parser from the other project to merge with
> the JPA project ?
> Am I doing something wrong ?
> Thanks in advance
I can understand your confusion, but this isn't really the forum to ask
this question in. Moreover, this question is really several questions.
I would suggest breaking up what you're trying to do into bite-sized
pieces and asking it in more appropriate forums. Use Google to help find
out about JPA projects. For instance, there's an older JPA tutorial at
vogella.com that might help.
You can get good help on SAX issues in stackoverflow.com. Search also
for tutorials or examples using SAX. There probably won't be anything
doing exactly what you want to do, so eat the elephant one spoonful at a
time.
Hope this helps.
FUDForum. Page generated in 0.08015 seconds
