SWT Visual Editor not showing correctly [message #900196] |
Sun, 05 August 2012 08:39 |
Khai Nodd Messages: 4 Registered: July 2009 |
I have eclipse Juno installed under oracle jdk 1.7.0_05 in Bodhi Linux, and the visual editor does not seem to work. The steps I took were just upgrading windowbuilder, and installing the SWT toolkit.
Then I create a new SWT/JFace Java Project and adding a new Shell, and open the "Design" tab. An error is then shown that disallows the editor to be used (I uploaded a screen capture with the exception shown in the error log).
Just in case, the message in the event details is:
Designer [1.5.0.r42x201206111201.201208051011]: org.eclipse.wb.internal.core.model.creation.ThisCreationSupport cannot be cast to org.eclipse.wb.internal.core.model.creation.ILiveCreationSupport
The Stacktrace:
java.lang.ClassCastException: org.eclipse.wb.internal.core.model.creation.ThisCreationSupport cannot be cast to org.eclipse.wb.internal.core.model.creation.ILiveCreationSupport
at org.eclipse.wb.internal.core.model.util.live.AbstractLiveManager.createClone(AbstractLiveManager.java:221)
at org.eclipse.wb.internal.swt.model.widgets.live.SwtLiveManager.createLiveComponent(SwtLiveManager.java:62)
at org.eclipse.wb.internal.core.model.util.live.AbstractLiveManager.createCacheEntryEx(AbstractLiveManager.java:103)
at org.eclipse.wb.internal.core.model.util.live.AbstractLiveManager.createCacheEntry(AbstractLiveManager.java:82)
at org.eclipse.wb.internal.core.model.util.live.AbstractLiveManager.getCachedEntry(AbstractLiveManager.java:264)
at org.eclipse.wb.internal.core.model.util.live.AbstractLiveManager.getCachedEntry(AbstractLiveManager.java:250)
at org.eclipse.wb.internal.swt.model.widgets.live.SwtLiveManager.getImage(SwtLiveManager.java:133)
at org.eclipse.wb.internal.swt.model.widgets.ControlInfo.getLiveImage(ControlInfo.java:138)
at org.eclipse.wb.core.model.AbstractComponentInfo.getImage(AbstractComponentInfo.java:165)
at org.eclipse.wb.core.gef.part.AbstractComponentEditPart$1.paintClientArea(AbstractComponentEditPart.java:91)
at org.eclipse.wb.draw2d.Figure.paintFigure(Figure.java:533)
at org.eclipse.wb.draw2d.Figure.paint(Figure.java:514)
at org.eclipse.wb.draw2d.Figure.paintChildren(Figure.java:552)
at org.eclipse.wb.draw2d.Figure.paint(Figure.java:516)
at org.eclipse.wb.internal.draw2d.FigureCanvas.handlePaint(FigureCanvas.java:188)
at org.eclipse.wb.internal.draw2d.FigureCanvas.access$2(FigureCanvas.java:160)
at org.eclipse.wb.internal.draw2d.FigureCanvas$3.handleEvent(FigureCanvas.java:150)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1300)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1285)
at org.eclipse.swt.widgets.Control.gtk_expose_event(Control.java:2992)
at org.eclipse.swt.widgets.Composite.gtk_expose_event(Composite.java:706)
at org.eclipse.swt.widgets.Canvas.gtk_expose_event(Canvas.java:167)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1754)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:5116)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4369)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8295)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1192)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2332)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3177)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
And the session data:
eclipse.buildId=I20120608-1400
java.version=1.7.0_05
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=es_ES
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
I've tried to reinstall eclipse and Windowbuilder several times, to no avail. Any clue?
Thank you (sorry about my english, I'm spanish), and keep the good work!
Attachment: captura.png
(Size: 88.74KB, Downloaded 321 times) -
Attachment: exception.png
(Size: 91.48KB, Downloaded 362 times)
FUDForum. Page generated in 0.27490 seconds
