User not found error while running reports in Stardust env [message #900115] |
Sat, 04 August 2012 07:26 |
Ganesh Lawande Messages: 5 Registered: February 2012 |
If you get following error in your BIRT reporting component while running Stardust reports, then the issue is likly related to JNDI name is not properely cofigured.
20120730 08:02:24,930 ERROR (WebContainer : 6) ProcessDatabaseQueryServiceEJB - javax.naming.NameNotFoundException: Name comp/env/jdbc not found in context "java:".
20120730 08:02:25,059 INFO (WebContainer : 6) ProcessDatabaseQueryServiceEJB - Worktime calculator class class ag.carnot.reporting.worktime.DefaultWorktimeC
alculator
20120730 08:02:25,059 INFO (WebContainer : 6) Connection - API <=== open()
20120730 08:02:25,060 INFO (WebContainer : 6) Connection - API ===> newQuery()
20120730 08:02:25,060 INFO (WebContainer : 6) Connection - API <=== getMetaData()
20120730 08:02:25,060 INFO (WebContainer : 6) Query - API ===> prepare()
20120730 08:02:25,080 INFO (WebContainer : 6) Query - API <=== prepare()
20120730 08:02:25,080 INFO (WebContainer : 6) Connection - API ===> getMetaData()
20120730 08:02:25,080 INFO (WebContainer : 6) DataSetMetaData - API ===> DataSetMetaData()
20120730 08:02:25,080 INFO (WebContainer : 6) DataSetMetaData - API <=== DataSetMetaData()
20120730 08:02:25,080 INFO (WebContainer : 6) Connection - API <=== getMetaData()
20120730 08:02:25,090 INFO (WebContainer : 6) Query - API ===> executeQuery()
FUDForum. Page generated in 0.03355 seconds
