Re: AUT starts but not recognized by Jubula [message #1005085 is a reply to message #900043] |
Thu, 24 January 2013 13:07 |
Alexander Berger Messages: 13 Registered: January 2013 |
Erik Gilbert wrote on Fri, 03 August 2012 11:33created new RCP test project.
connected to AUT Agent localhost port 60000
click Start AUT
The executable defined in the AUT starts up and lauches successfully. There is quite a bit of logging information that appears in the console window of the the AUT agent.
But on Jubula, the Progress tab shows the message: Starting AUT with ID and this message just stays there like that
The Running AUTs tab remains empty.
After 2 minutes, a Usage Hint box appears :
Two minutes have elapsed since you initialized starting procedure of your RCP AUT.
Please make sure that you have followed all instructions in the User Manual, chapter 'Testing RCP AUTs.'
I click Proceed, but the 'Starting AUT with ID' message appears in the Progress tab. Even though the AUT is started, Jubula never recognizes that it has started.
no error messages appear in the log files
I have the same Problem.
Even when I click "start AUT" toolbar button the excutable file starts up.
But the Progress tab shows the message: Starting AUT with ID and the "Running AUTs" view is empty.
After 2 minutes the same "Usage hint" box pop up.
I have unzip the "rcp-support.zip" and edit the config.
Here my config.ini file shortened:
osgi.bundles=WP2,\
ca.odell.glazedlists,\
ch.qos.logback.classic,\
ch.qos.logback.core,\
com.ibm.icu,\
org.eclipse.m2e.logback.appender,\
org.eclipse.swt.win32.win32.x86,\
org.eclipse.ui.win32,\
org.eclipse.jubula.rc.rcp
Re: AUT starts but not recognized by Jubula [message #1005398 is a reply to message #900043] |
Fri, 25 January 2013 09:05 |
Thank you for you response.
I have tried the AUT configuration with using the -data option in the AUT Arguments, without results...
When I click "start AUT" button the login screen pop up, but the the "Running AUTs" is empty.
The "Start AUT Agent" show me this Error just after the Log-In:
"AUT:Error while painting table: java.lang.ArrayIndexOutOfBoundsException: -1"
The RCP application was created with e4...
The file directory for the plugin:
C:\WP2\WP2\plugins
The config.ini file
osgi.bundles=WP2,\
com.ibm.icu,\
And the AUT configuration:
[Updated on: Mon, 28 January 2013 08:35] Report message to a moderator
FUDForum. Page generated in 0.05363 seconds
