vxml not generated properly using OpenVxml 4.0 [message #899160] |
Mon, 30 July 2012 17:18 |
Amal Antony Messages: 3 Registered: July 2012 |
I am new to OpenVxml. I have installed OpenVxml 4.0 on my machine and developed a simple call flow begin-->Play Prompt--> return. when I deploy the war,and try to view the vxml in the browser, this is what I see
vxml version="2.1"><form id="EndMessageForm" scope="document"><block name="EndMessageBlock"><exit/></block></form></vxml>
I tried different call-flows but everytime I am seeing the above pasted vxml in browser. Can anybody please tell me what could have gone wrong. I have tried deploying the war on tomcat as well as jboss, but getting the same result
Thanks and regards,
Amal
[Updated on: Mon, 30 July 2012 17:19] Report message to a moderator
Re: vxml not generated properly using OpenVxml 4.0 [message #899244 is a reply to message #899160] |
Tue, 31 July 2012 08:26 |
Kevin Smith Messages: 7 Registered: May 2012 |
Hi Amal,
What URL are you using to access the application? For reference, the URL should be:
<server>:<port>/<war name>/<project name>/<entry point>
So if you had a project called 'MyDemo' with the default entry point of 'Begin' and you exported it to 'Example.war', the URL would be:
www.yourserver.com:8080/Example/MyDemo/Begin
...with the appropriate host and port ofc.
[Updated on: Tue, 31 July 2012 08:27] Report message to a moderator
FUDForum. Page generated in 0.03397 seconds
