Re: open eclipse perspective in eclipse from command line [message #899361 is a reply to message #899299] |
Tue, 31 July 2012 14:36 |
What about supplying a default perspective in the WorkbenchAdvisor?
WorkbenchAdvisor.getInitialWindowPerspectiveId() {
return "your.perspective.id";
If you are looking to restore the last perspective try:
WorkbenchAdvisor.initialize(IWorkbenchConfigurer configurer) {
super.initialize(configurer);
configurer.setSaveAndRestore(true);
These would be better and more generally accepted ways of loading your perspective.
JD
Re: open eclipse perspective in eclipse from command line [message #899951 is a reply to message #899361] |
Fri, 03 August 2012 07:43 |
Definitively agreed with Josehp. Make use of "-perspetive" place further
burden on you as you must manage eclipse(yourProduct).ini and product
definitions up-to-date with default perspective. Programmatic approach
also enables to have complex logic deciding about perspective to open.
Libor
> perspective.
> JD
FUDForum. Page generated in 0.03919 seconds
