Home » Archived » Koneki » Problem Starting Koneki with DM-Server 3.6(Can't connect Koneki to Funambol DM-Server 3.6 after success install)
| Problem Starting Koneki with DM-Server 3.6 [message #897575] |
Tue, 24 July 2012 10:59  |
Hello. I'm kinda new to this world, i'm trying to setup the funambol dm-server 3.6 and Koneki. I've followed this guide to install and setup both Koneki and DM-Server:
http://wiki.eclipse.org/Koneki/Simulators/OMA-DM/User_Guide
I'm on opensuse 11.4, every Ambient variable are set to the right place, i can install the jboss5 and set up the data base without any problem.
The DM-Server starts up just fine (at least i guess), after that i create a new ID to use and try to connect via Koneki and then i get the following exception:
15:51:17,058 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,086 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,183 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,619 ERROR [STDERR] org.jibx.runtime.JiBXException: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
15:51:17,620 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalElement(UnmarshallingContext.java:2565)
15:51:17,620 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalDocument(UnmarshallingContext.java:2736)
15:51:17,620 ERROR [STDERR] at com.funambol.server.engine.SyncAdapter.processMessage(SyncAdapter.java:287)
15:51:17,620 ERROR [STDERR] at com.funambol.server.syncbean.SyncBean.processMessage(SyncBean.java:228)
15:51:17,620 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
15:51:17,620 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
15:51:17,620 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
15:51:17,620 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
15:51:17,621 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
15:51:17,621 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
15:51:17,621 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
15:51:17,621 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_1852690398.invoke(InvocationContextInterceptor_z_fillMethod_1852690398.java)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
15:51:17,622 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_1852690398.invoke(InvocationContextInterceptor_z_setup_1852690398.java)
15:51:17,622 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.entity.ExtendedPersistenceContextPropagationInterceptor.invoke(ExtendedPersistenceContextPropagationInterceptor.java:60)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.stateful.StatefulInstanceInterceptor.invoke(StatefulInstanceInterceptor.java:81)
15:51:17,622 ERROR [STDERR] at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
15:51:17,622 ERROR [STDERR] at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
15:51:17,623 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,623 ERROR [STDERR] at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
15:51:17,623 ERROR [STDERR] at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:176)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:216)
15:51:17,624 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
15:51:17,624 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
15:51:17,624 ERROR [STDERR] at $Proxy266.processMessage(Unknown Source)
15:51:17,624 ERROR [STDERR] at com.funambol.transport.http.server.LocalEJBSyncHolder.processMessage(LocalEJBSyncHolder.java:88)
15:51:17,624 ERROR [STDERR] at com.funambol.transport.http.server.Sync4jServlet.doPost(Sync4jServlet.java:250)
15:51:17,624 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
15:51:17,624 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
15:51:17,624 ERROR [STDERR] at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
15:51:17,624 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
15:51:17,625 ERROR [STDERR] at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
15:51:17,625 ERROR [STDERR] at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
15:51:17,625 ERROR [STDERR] at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
15:51:17,625 ERROR [STDERR] at java.lang.Thread.run(Thread.java:662)
15:51:17,625 FATAL [SyncAdapter] Error unmarshalling message: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
15:51:17,647 ERROR [[SyncServerServlet]] Servlet.service() for servlet SyncServerServlet threw exception
I'm Doing something wrong? i've look to the guide number of times and i don't understand what i may be doing wrong...
I can see it's something related to the SyncML 1.2 unmarshal. But i have look time and time again on the web on the forum and nothing i can't find any solution to this..
[Updated on: Tue, 24 July 2012 11:02] by Moderator
| Re: Problem Starting Koneki with DM-Server 3.6 [message #904135 is a reply to message #897575] |
Mon, 27 August 2012 17:08   |
I have exactly the same issue as Andre. Installation of JBoss, Koneki and Funambol worked fine, I can access the Funambol and JBoss web interface, the devices I create get stored in the database.
But when I want to connect with Koneki, the following happens:
Koneki shows an alert with "HTTP/1.1 500 Internal Server Error" and I get the same error log as Andre:
22:54:36,133 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,137 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,171 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,172 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,389 ERROR [STDERR] org.jibx.runtime.JiBXException: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
22:54:36,390 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalElement(UnmarshallingContext.java:2565)
22:54:36,390 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalDocument(UnmarshallingContext.java:2736)
22:54:36,390 ERROR [STDERR] at com.funambol.server.engine.SyncAdapter.processMessage(SyncAdapter.java:287)
22:54:36,391 ERROR [STDERR] at com.funambol.server.syncbean.SyncBean.processMessage(SyncBean.java:228)
22:54:36,391 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
22:54:36,391 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
22:54:36,391 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
22:54:36,391 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:616)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_10922545.invoke(InvocationContextInterceptor_z_fillMethod_10922545.java)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
22:54:36,398 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_10922545.invoke(InvocationContextInterceptor_z_setup_10922545.java)
22:54:36,398 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.entity.ExtendedPersistenceContextPropagationInterceptor.invoke(ExtendedPersistenceContextPropagationInterceptor.java:60)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
22:54:36,399 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.stateful.StatefulInstanceInterceptor.invoke(StatefulInstanceInterceptor.java:81)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
22:54:36,405 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,405 ERROR [STDERR] at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
22:54:36,406 ERROR [STDERR] at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
22:54:36,406 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:176)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:216)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
22:54:36,406 ERROR [STDERR] at $Proxy266.processMessage(Unknown Source)
22:54:36,406 ERROR [STDERR] at com.funambol.transport.http.server.LocalEJBSyncHolder.processMessage(LocalEJBSyncHolder.java:88)
22:54:36,406 ERROR [STDERR] at com.funambol.transport.http.server.Sync4jServlet.doPost(Sync4jServlet.java:250)
22:54:36,406 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
22:54:36,406 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
22:54:36,406 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
22:54:36,406 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
22:54:36,406 ERROR [STDERR] at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
22:54:36,407 ERROR [STDERR] at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
22:54:36,407 ERROR [STDERR] at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
22:54:36,407 ERROR [STDERR] at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
22:54:36,408 ERROR [STDERR] at java.lang.Thread.run(Thread.java:636)
22:54:36,408 FATAL [SyncAdapter] Error unmarshalling message: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
22:54:36,425 ERROR [[SyncServerServlet]] Servlet.service() for servlet SyncServerServlet threw exception
Any ideas? Are there any Funambol servers out there which are open to use? This way I could at least check if my Koneki is working correctly.
Thanks in advance,
Brandon
| Re: Problem Starting Koneki with DM-Server 3.6 [message #908609 is a reply to message #908433] |
Wed, 05 September 2012 12:30   |
Hello, and thank you Brandon for your excellent post explaining every step of the way. But i'm out of luck for sure I tried exactly as u wrote, step by step, using the same components in the same version. The OS is exactly the same, the virtual machine is VirtualBox 4.1.20 (can't be that), the java version is also the same installed trough apt-get aswell. The eclipse was installed via apt-get as well... Alcomponents are inside the virtual machine, altho the host syste is on 64bits, but the vm i insalled is the 32bit one. Everything "by the book" and still got that error message saying it has no unmarshaller for element {SYNCML:SYNCML1.2}SYNCML :S.
I'm so frustrated right now..
I don't understand much yet about unmarshaller elements, but i think they have to be in one specific document, is it possible that need document is missing from my installation by any reason?
I can also leave the debug messages given by the eclipse during the connection, it may help on something:
root@atomas-VirtualBox:/opt# 19:07:01.578 [pool-1-thread-1] DEBUG o.a.h.i.c.t.ThreadSafeClientConnManager - Get connection: ht*pRoute[{}->ht*p://localhost:8080], timeout = 0
19:07:01.608 [pool-1-thread-1] DEBUG o.a.h.i.conn.tsccm.ConnPoolByRoute - [ht*pRoute[{}->ht*p://localhost:8080]] total kept alive: 0, total issued: 0, total allocated: 0 out of 20
19:07:01.609 [pool-1-thread-1] DEBUG o.a.h.i.conn.tsccm.ConnPoolByRoute - No free connections [ht*pRoute[{}->ht*p://localhost:8080]][null]
19:07:01.610 [pool-1-thread-1] DEBUG o.a.h.i.conn.tsccm.ConnPoolByRoute - Available capacity: 2 out of 2 [ht*pRoute[{}->ht*p://localhost:8080]][null]
19:07:01.610 [pool-1-thread-1] DEBUG o.a.h.i.conn.tsccm.ConnPoolByRoute - Creating new connection [ht*pRoute[{}->ht*p://localhost:8080]]
19:07:01.674 [pool-1-thread-1] DEBUG o.a.h.i.c.DefaultClientConnectionOperator - Connecting to localhost/127.0.0.1:8080
19:07:01.791 [pool-1-thread-1] DEBUG o.a.h.c.protocol.RequestAddCookies - CookieSpec selected: best-match
19:07:01.940 [pool-1-thread-1] DEBUG o.a.h.impl.client.Defaultht*pClient - Attempt 1 to execute request
19:07:01.956 [pool-1-thread-1] DEBUG o.a.h.i.conn.DefaultClientConnection - Sending request: POST /funambol/dm ht*p/1.1
19:07:01.963 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "POST /funambol/dm ht*p/1.1[\r][\n]"
19:07:01.966 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "Transfer-Encoding: chunked[\r][\n]"
19:07:01.978 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "Content-Type: application/vnd.syncml.dm+xml[\r][\n]"
19:07:01.986 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "Content-Encoding: UTF-8[\r][\n]"
19:07:01.987 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "Host: localhost:8080[\r][\n]"
19:07:01.988 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "Connection: Keep-Alive[\r][\n]"
19:07:01.992 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "User-Agent: Apache-ht*pClient/4.1 (java 1.5)[\r][\n]"
19:07:01.993 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "[\r][\n]"
19:07:01.998 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - >> POST /funambol/dm ht*p/1.1
19:07:01.998 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - >> Transfer-Encoding: chunked
19:07:01.999 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - >> Content-Type: application/vnd.syncml.dm+xml
19:07:01.999 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - >> Content-Encoding: UTF-8
19:07:01.999 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - >> Host: localhost:8080
19:07:02.000 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - >> Connection: Keep-Alive
19:07:02.000 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - >> User-Agent: Apache-ht*pClient/4.1 (java 1.5)
19:07:02.136 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "420[\r][\n]"
19:07:02.150 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "<?xml version="1.0" encoding="UTF-8"?><SyncML xmlns="SYNCML:SYNCML1.2"><SyncHdr><VerDTD>1.2</VerDTD><VerProto>DM/1.2</VerProto><SessionID>1</SessionID><MsgID>1</MsgID><Target><LocURI>ht*p://localhost:8080/funambol/dm</LocURI></Target><Source><LocURI>MyID</LocURI></Source><Cred><Meta><Format xmlns="syncml:metinf">b64</Format><Type xmlns="syncml:metinf">syncml:auth-basic</Type></Meta><Data>ZnVuYW1ib2w6ZnVuYW1ib2w=</Data></Cred></SyncHdr><SyncBody><Alert><CmdID>1</CmdID><Data>1201</Data></Alert><Replace><CmdID>2</CmdID><Meta><Format xmlns="syncml:metinf">chr</Format><Type xmlns="syncml:metinf">text/plain</Type></Meta><Item><Source><LocURI>./DevInfo/DevId</LocURI></Source><Data>MyID</Data></Item><Item><Source><LocURI>./DevInfo/DwV</LocURI></Source><Data></Data></Item><Item><Source><LocURI>./DevInfo/Man</LocURI></Source><Data>Samssung</Data></Item><Item><Source><LocURI>./DevInfo/Mod</LocURI></Source><Data>P-1000G</Data></Item><Item><Source><LocURI>./DevInfo/Lang</LocURI></Source><Data>PT</Data></Item></Replace><Final></Final></SyncBody></SyncML>"
19:07:02.155 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "[\r][\n]"
19:07:02.523 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "0[\r][\n]"
19:07:02.525 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - >> "[\r][\n]"
19:07:03.388 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - << "ht*p/1.1 500 Internal Server Error[\r][\n]"
19:07:03.407 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - << "Server: Apache-Coyote/1.1[\r][\n]"
19:07:03.407 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - << "Content-Type: text/html;charset=utf-8[\r][\n]"
19:07:03.408 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - << "Transfer-Encoding: chunked[\r][\n]"
19:07:03.408 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - << "Date: Wed, 05 Sep 2012 18:07:03 GMT[\r][\n]"
19:07:03.408 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - << "Connection: close[\r][\n]"
19:07:03.408 [pool-1-thread-1] DEBUG org.apache.ht*p.wire - << "[\r][\n]"
19:07:03.410 [pool-1-thread-1] DEBUG o.a.h.i.conn.DefaultClientConnection - Receiving response: ht*p/1.1 500 Internal Server Error
19:07:03.410 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - << ht*p/1.1 500 Internal Server Error
19:07:03.410 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - << Server: Apache-Coyote/1.1
19:07:03.411 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - << Content-Type: text/html;charset=utf-8
19:07:03.411 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - << Transfer-Encoding: chunked
19:07:03.411 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - << Date: Wed, 05 Sep 2012 18:07:03 GMT
19:07:03.411 [pool-1-thread-1] DEBUG org.apache.ht*p.headers - << Connection: close
[Updated on: Wed, 05 September 2012 14:14] by Moderator
| Re: Problem Starting Koneki with DM-Server 3.6 [message #908654 is a reply to message #897575] |
Wed, 05 September 2012 14:34   |
Hey,
I'm actually out of ideas now.
I uploaded my dm-server folder, my .profile file and an overview over all installed packages here:
h*tp://netload.in/datei934otcRlvI/dm-server.tar.bz2.htm
Unzip it with the command "tar xfvj dm-server.tar.bz2" if there is no GUI tool for that. You can create a list of all installed packages with "dpkg -l > packages.txt".
Remember to edit the .profile file and the file dm-server/install.properties. Maybe you should just copy all the files to the folder /home/USERNAME/funambol/Funambol.
So this folder should contain:
- the folder "dm-server" copied from my archieve
- the folder "jboss-5.1.0.GA", maybe you should download it again (remember, the -SDK version)
- the file "postgresql-9.1.902.jdbc3.jar"
Then you just have to edit the .profile and the dm-server/install.properties the way that you overwrite the word "USER" with your username. And maybe doublecheck the database account.
Oh and maybe you should check the rights on all the files and folders. If you don't care about the rights, I think a "chmod -R 777" on the folder funambol would definitely be worth a try!
When you did all of this and it won't work, I really have no clue how to help. If you have any ideas what you would like to check, let me know. My last idea would be a complete image of my VM, but this would be several gigabyte and with my internet connection it would take forever to upload.
Best of luck,
Brandon
P.S.: Oh and I doubt debugging the code is worth trying, in my opinion is a problem with the installation since I had the same problem and it got solved by choosing the right software environment.
[Updated on: Wed, 05 September 2012 14:38] by Moderator
| Re: Problem Starting Koneki with DM-Server 3.6 [message #909075 is a reply to message #908654] |
Thu, 06 September 2012 09:45   |
I've analised every packet comparing to Brandon F file. The based packets were the same, there were some codec packets and video ones that i didn't install same for language ones. I used the .profile file you gave me, btw, thank you for the time spent gathering the material, i've used your funambol server, changing only the install.properties, used my home folder exactly like you told me, checked the postgresql server, permissions, user and database, everything was ok. I also didn't forgot to change the files permissions i've used the chmod 777 as you recomended.
Downloaded again the Jboss with the -SDK and the postgresql obdc driver, run the install.sh jboss5, everything ok (build success), then start.sh and no problems i could see in the startup. Then, wehn i tried out connect with koneki, same error..
My biggest fear is missing something on the installation process of the server and because of that i'm getting this error :S
My last try will be do this on a new machine, install the ubuntu on a usb-stick with persistante changes and see what happens there.
Thank you again Brandon for you time, and thank you Benjamin for the start up help.
Anyway ill keep you posted till the end of day how it all went with this installation.
EDIT: Tell me something if you know, do the system go outside, onto the network search for a file or something like that on a specific port or protocol???
[Updated on: Thu, 06 September 2012 09:53] by Moderator
| Re: Problem Starting Koneki with DM-Server 3.6 [message #909224 is a reply to message #909075] |
Thu, 06 September 2012 14:57   |
I finally manage to get the funambol server communicate with the Koneki
Not in Linux, i have no idea what so ever why, but in windows 7, i learn a lot with each try and noticed there were some ".cmd" files, then i thought the process should be the same, it was quite similar, but not totally equal, but its working now, and i can finally start to do domething good with it
Again thank you guys for kept trying to help me and by doing so i didn't give up. Sad as to be on windows, but at least is working.
When i got some more time i'll try to understand why i couldn't install the server on linux.
Do you like me to post the changes need to put the server running on windows? (DM-Server, the koneki part is the same )
| Re: Problem Starting Koneki with DM-Server 3.6 [message #909551 is a reply to message #909471] |
Fri, 07 September 2012 06:17   |
Brandon F wrote on Fri, 07 September 2012 03:48
If you rather want to use Linux (and if you want to give it one last try) I could install everything again myself and write down every step and command, like a walkthrough.
I think that's not a big priority for me, linux or windows, i just wanted to see the packages exchange and how some specific messages are built.
Thanks anyway, you already spend so much time with me.
But when i got some more free time, i really would like to try it one more time from a full clean Linux again and see if it works or not.
Benjamin Cabe wrote on Fri, 07 September 2012 04:07
BTW guys, I'd be very interested in knowing more about what you are doing with OMA-DM, if you can share!
I'm trying to build an ANDSF core so the operator can manage policies inside the mobile phone of the client. And so, ANDSF uses OMA-DM principle to exchange messages and sync and somethings more.. thats my project
[Updated on: Fri, 07 September 2012 06:18] by Moderator
| Re: Problem Starting Koneki with DM-Server 3.6 [message #1066984 is a reply to message #1029960] |
Fri, 05 July 2013 06:50   |
We experience the same problem here as the others.
dm-server looks good, but the when connecting /funambol/dm we have the same error message.
The system is Ubuntu 13.04, I have tried Funambol versions:
3.5.1, bundled with hsql, java and jboss 3.2, no distribution-dependent component at all.
3.6 with jboss 4.1, and Sun Java 1.7
3.7 with tomcat7 and openjdk7
the result is the same for all... /dmdemo works fine, but /funambol/dm drops the "unsupported method" message.
Anyway, what should happen if I just open a browser and point to ht2p://localhost:8080/funambol/dm ?? 'cos now the error happens, but the guys developing the client reports the same error when connecting with the sample koneki client as well!
| Re: Problem Starting Koneki with DM-Server 3.6 [message #1416647 is a reply to message #908654] |
| Re: Problem Starting Koneki with DM-Server 3.6 [message #1416648 is a reply to message #1416647] |
I finally manage to get the funambol server communicate with the Koneki :)
Not in Linux, i have no idea what so ever why, but in windows 7, i learn a lot with each try and noticed there were some ".cmd" files, then i thought the process should be the same, it was quite similar, but not totally equal, but its working now, and i can finally start to do domething good with it :)
Do you like me to post the changes need to put the server running on windows? (DM-Server, the koneki part is the same :) )
| Re: Problem Starting Koneki with DM-Server 3.6 [message #1416651 is a reply to message #909471] |
I'm trying to build an ANDSF core so the operator can manage policies inside the mobile phone of the client. And so, ANDSF uses OMA-DM principle to exchange messages and sync and somethings more.. thats my project :)
| Re: Problem Starting Koneki with DM-Server 3.6 [message #1417123 is a reply to message #909551] |
Fri, 09 May 2014 04:58  |
Hi Andre ,
I am also doing work on same.I installed DM server 3.7 .But my simulator is not able to connect with server.Please help me this.
I am also working on same project to push policies to (MO object ) to UE.Can you have any other server to test it (Guide) .
Thank you so much.
Current Time: Thu Nov 06 10:13:13 EST 2025
Powered by FUDForum. Page generated in 0.13797 seconds
