Home » Modeling » EMF » Transform exiting model and save to .uml
Transform exiting model and save to .uml [message #897362] Mon, 23 July 2012 14:44 Go to next message
Hey guys I am currently working on a project where I try to generate Code from existing UML Models which contain class diagrams and state machines. Therefore I need to flatten and resolve history states at first. I get the Models as an XMI file (created with Topcased). Now I want to load the model transform it and save it again. The loading and transforming works fine but I have trouble saving my model I always get a NullPointerException
Exception in thread "main" java.lang.NullPointerException
	at Main.save(Main.java:54)
	at Main.main(Main.java:19)
I followed the Getting started with UML2 guide. Here is my code so far:
import java.io.IOException;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.mapping.ecore2xml.util.Ecore2XMLResource;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.internal.impl.StateImpl;
import org.eclipse.uml2.uml.resource.UMLResource;
import org.eclipse.uml2.uml.resource.XMI2UMLResource;
public class Main {
	public static void main(String[] args){
		Model m=new Main().getModel("Some Path");
        save(m, URI.createURI("Some Path").appendSegment("newModel").appendFileExtension(UMLResource.FILE_EXTENSION));
		//System.out.println(m.getName());
        System.out.println("Done.");
	public Model getModel(String pathToModel) {
		URI typesUri = URI.createFileURI(pathToModel);
		ResourceSet set = new ResourceSetImpl();
		set.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
		set.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
		set.createResource(typesUri);
		Resource r = set.getResource(typesUri, true);
        Model m = (Model) EcoreUtil.getObjectByType(r.getContents(), UMLPackage.Literals.MODEL);
		return m;
	// Do some transformations on model
	protected static void save(org.eclipse.uml2.uml.Package package_, URI uri)
        Resource resource = new ResourceSetImpl().createResource(uri);
        resource.getContents().add(package_);
        try {
            resource.save(null);
        } catch (IOException ioe)  {}
I am thankful for any input regarding my problem!
regards
Florian
Re: Transform exiting model and save to .uml [message #897367 is a reply to message #897362] Mon, 23 July 2012 15:46 Go to previous messageGo to next message
Somehow I solved the problem I simply added a few lines inside the save method It now looks like this:
		Resource.Factory.Registry reg = Resource.Factory.Registry.INSTANCE;
		Map<String, Object> m = reg.getExtensionToFactoryMap();
		m.put(Resource.Factory.Registry.DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
        try {
Cheers
Re: Transform exiting model and save to .uml [message #897370 is a reply to message #897367] Mon, 23 July 2012 15:59 Go to previous messageGo to next message
Florian,
If you're saving UML instances you should use UML2's resource factory.
> uri)
> try {
> Cheers
Re: Transform exiting model and save to .uml [message #897377 is a reply to message #897370] Mon, 23 July 2012 16:23 Go to previous message
Correctly configuring UML is really hard.
As of Juno just use UMLResourcesUtil.init().
Ed Willink
On 23/07/2012 20:59, Ed Merks wrote:
> Florian,
>> uri)
>> try {
>> Cheers
Previous Topic:EMF/XSD invalid xml
Next Topic:Definition and data editor
Current Time: Wed Oct 22 12:58:48 EDT 2025
Powered by FUDForum. Page generated in 0.42815 seconds
