Re: Code Assistance for external lib [message #898765 is a reply to message #897083] |
Fri, 27 July 2012 13:38 |
Simon Bernard Messages: 345 Registered: July 2009 |
You could do that with LuaDocumentator and even create an Execution Environment if you want to shared it easily.
LuaDocumentator is a documentation language like javadoc or luadoc which will allow you to express your API.
So you could write the API of your modules with it.
If the file are in your source path, this will activate some user assistance.
Then, you could regroup all your API file, in an Execution Environment. You could read the documentation to know how to build one.
There are already some execution environment available.
You could download and add one of them to test the user assitance and see the possibilities.
HTH
[Updated on: Fri, 27 July 2012 13:39] Report message to a moderator
FUDForum. Page generated in 0.03843 seconds
