Home » Archived » Code Recommenders » Problems updating from HEAD Updatesite
Problems updating from HEAD Updatesite [message #896986] |
Fri, 20 July 2012 16:37 |
Since 3 days i'm trying to update CodeRecommendors from:
http://download.eclipse.org/recommenders/updates/head/e42/
but i get this errors:
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.calls,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.chain,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.e38,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.overrides,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.subwords,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.templates,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.doc,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.extdoc,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.extdoc.rcp,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.injection,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.jayes,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.jayes.serialization,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.rcp,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.utils,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.utils.rcp,1.0.0.v20120720-1219-b604
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.3rd.orbit,1.0.0.v20120720-1219-b604
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.3rd.rcp.nonorbit,1.0.0.v20120720-1219-b604
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.completion.rcp.chain,1.0.0.v20120720-1219-b604
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.completion.rcp.intellig,1.0.0.v20120720-1219-b604
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.completion.rcp.subwords,1.0.0.v20120720-1219-b604
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.extdoc.rcp,1.0.0.v20120720-1219-b604
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.rcp.core,1.0.0.v20120720-1219-b604
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.snipmatch.rcp,1.0.0.v20120720-1219-b604
No repository found containing: osgi.bundle,org.eclipse.recommenders.snipmatch.rcp,1.0.0.v20120720-1219-b604
Running Eclipse 4.2 64Bit on Windows7 64Bit with JDK 1.7u5 64Bit.
any solutions for this issue?
[Updated on: Fri, 20 July 2012 16:39] Report message to a moderator
Re: Problems updating from HEAD Updatesite [message #897410 is a reply to message #897387] |
Tue, 24 July 2012 03:38 |
Sorry for the delay. This post didn't show up in my RSS feed.
The installation works for me using these selections:
Could you check if above selection settings would work for you? If not, I assume it's a mirror issue that needs a little more work but can be fixed. Please let me know if the installation works with the above settings.
Marcel
Re: Problems updating from HEAD Updatesite [message #897412 is a reply to message #897410] |
Tue, 24 July 2012 03:47 |
BTW:
I just noticed you are trying to download build "b604". Head update site only contains "b607".
As this update site is filled by the build server automatically and old versions are deleted, I hope this is not a caching issue of your Eclipse. Could you make sure to restart your IDE before checking the download site again?
Re: Problems updating from HEAD Updatesite [message #897417 is a reply to message #897412] |
Tue, 24 July 2012 04:51 |
Good morning Marcel,
thanks for your reply. (Finally, my pleading is heard. )
Marcel Bruch wrote on Tue, 24 July 2012 05:47BTW:
Right, "b604" was the current version on Friday and I tried to upgrade from b598 to b604.
Yesterday and today I tried to upgrade from b598 (current installed plugin version on my Eclipse) to b607 (current version @HEAD-updatesite) with a new clean workspace and also got this error:
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.calls,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.chain,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.e38,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.overrides,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.subwords,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.completion.rcp.templates,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.doc,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.extdoc,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.extdoc.rcp,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.injection,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.jayes,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.jayes.serialization,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.rcp,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.utils,1.0.0.v20120723-0339-b607
No repository found containing: osgi.bundle,org.eclipse.recommenders.utils.rcp,1.0.0.v20120723-0339-b607
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.3rd.orbit,1.0.0.v20120723-0339-b607
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.3rd.rcp.nonorbit,1.0.0.v20120723-0339-b607
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.completion.rcp.chain,1.0.0.v20120723-0339-b607
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.completion.rcp.intellig,1.0.0.v20120723-0339-b607
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.completion.rcp.subwords,1.0.0.v20120723-0339-b607
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.extdoc.rcp,1.0.0.v20120723-0339-b607
No repository found containing: org.eclipse.update.feature,org.eclipse.recommenders.feature.rcp.core,1.0.0.v20120723-0339-b607
Now, i uninstalled recommenders (b598) and tried to reinstall it (b607) with your recommended selection but i still got the same error.
I can't update or install Code-Recommender from HEAD-Updatesite and DEV-Updatesite (got the same error as on HEAD).
If i'm using STABLE-Updatesite (with b156 on it) i got this error:
No repository found containing: osgi.bundle,org.slf4j.jcl,1.6.4.v20120130-2120
Contents of my eclipse.ini:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120522-1813
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
1024m
--launcher.defaultAction
openFile
-vm
D:/installed/Java/JDK_1.7.5_64bit/bin/javaw.exe
-vmargs
-Declipse.p2.unsignedPolicy=allow
-Xss4m
-XX:+UnlockExperimentalVMOptions
-Xms1024m
-Xmx2048m
-Dsun.lang.ClassLoader.allowArraySyntax=true
I never had a problem with this configuration since Eclipse 4.2 was released.
But in the past I've discovered that some plugins may have problems with several parameters in the eclipse.ini and could not be installed or updated.
I had no problems installing the version B598 with this eclispe.ini.
Maybe some parameters are also the cause. I don't know.
If you ever can afford some time for a solution to this problem I would be very grateful. But it is not urgent.
BTW: I'm here in Germany, maybe it is relevant for the "mirror thing" ?
Thanks alot,
Enrico
Re: Problems updating from HEAD Updatesite [message #897556 is a reply to message #897493] |
Tue, 24 July 2012 13:36 |
Marcel, as I mentioned in an email: if you change the contents of content.jar, artifacts.jar or any other file under that directory, you must update the timestamp of the /recommenders/updates/head/e42/ also. Otherwise, all the mirrors will be shown despite there being changes to the contents which have not propagated.
Please let me know if you need more information.
Denis
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
Re: Problems updating from HEAD Updatesite [message #898100 is a reply to message #897556] |
Wed, 25 July 2012 19:26 |
Hello, me again with a little additional information about this problem.
I have found out that this problem was not only related to the recommenders updatesite.
I couldn't install or update any plugin where the updatesite is pointing to "download.eclipse.org/*". Updating or installing from another updatesite exept to "download.eclipse.org/*" works fine.
Maybe something went wrong in my eclipse installation but I don't know what exactly. I was able to show all plugins via the updatemanager but i was unable to download them.
Now I have setup a complete new Eclipse 4.2 installation and all updatesites pointing to "*.eclipse.org" works fine for now, also the original recommenders updatesite (download.eclipse.org/recommenders/updates/head/e42/).
I have nothing changed on my system configuration (firewall, antivirus or any network related settings).
Nevertheless, many thanks to you for your help!
best regards
Enrico
Current Time: Fri Apr 26 01:15:07 GMT 2024
Powered by FUDForum. Page generated in 0.03949 seconds
