Home » Eclipse Projects » Rich Client Platform (RCP) » Running a 3.x RCP application with Eclipse 4.2
Running a 3.x RCP application with Eclipse 4.2 [message #896953] Fri, 20 July 2012 10:04 Go to next message
According to a tutorial by Lars Vogel, if I grab my 3.x RCP application and I've already got it configured to use features, I should be able to run it from Eclipse 4.2 without making any change.
I tried but I keep getting the following error:
!SESSION Fri Jul 20 15:54:00 CEST 2012 -----------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2012-07-20 15:54:00.725
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:626)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Is there anyone who could help me finding out what's going wrong? Please let me know what details you need.
Re: Running a 3.x RCP application with Eclipse 4.2 [message #896960 is a reply to message #896953] Fri, 20 July 2012 10:25 Go to previous message
I've got it working by changing the configuration and adding all the required plugins again.
Now that the application is starting up, I'm still having an issue in my ApplicationWorkbenchAdvisor because the following call which worked on 3.x is returning null now:
this.getWorkbenchConfigurer().getWorkbench().getActiveWorkbenchWindow().getShell()
Any clues? Thanks!
Update:
I found the solution, I should have been doing this in the window advisor.
[Updated on: Fri, 20 July 2012 12:00] by Moderator
Previous Topic:Save reference of input of a Part
Next Topic:JFace Databinding for editable viewer
Current Time: Fri Sep 26 12:13:12 EDT 2025
Powered by FUDForum. Page generated in 0.02320 seconds
