Re: [xcore] Code Snippet ignored with derived and refers references [message #896845 is a reply to message #896746] |
Fri, 20 July 2012 06:36 |
Ed Merks Messages: 33216 Registered: July 2009 |
Comments below.
On 19/07/2012 4:57 PM, Régent L Archevêque wrote:
> Hi Ed,
> I really like the new way to create meta-model.
It's a look more awesome. :-P
> So far, it is going well. Just a little question. I have the
> following model
> class EVariable extends ENamedElement{
> container EVariables eVariables opposite eVariables
Usually I don't like pluralized names for classes. It makes it hard to
write well formed English sentences with the. E.g., "I used the
generated factory to create an EVariables."
> refers EClass eClass
> @GenModel(children="false", property="Readonly")
> refers readonly volatile transient derived EProgram eProgram get{
It seemed so common for a derived feature to be readonly, transient, and
volatile that this is implied by "derived". We'll need to look at
keyword to specify otherwise.
> if (EVariables == null) return null else return EVariables.EProgram
You should be able to use EVariables?.EProgram. (I'm not so happy with
Xbase's initial upper case letter here.)
> The code generated is the following:
> * <!-- begin-user-doc -->
> * <!-- end-user-doc -->
> * @generated
> public EProgram getEProgram()
> EProgram eProgram = basicGetEProgram();
> return eProgram != null && eProgram.eIsProxy() ?
> (EProgram)eResolveProxy((InternalEObject)eProgram) : eProgram;
I would have expected the body you specified. Please open a bugzilla.
I'll address this in the maintenance stream. We've just set up builds
for that so builds will be available soon.
> * @generated
> public EProgram basicGetEProgram()
> // TODO: implement this method to return the 'EProgram' reference
> // -> do not perform proxy resolution
> // Ensure that you remove @generated or mark it @generated NOT
> throw new UnsupportedOperationException();
If you added the keyword "local" before or right after the "refers" to
specify that this feature isn't proxy resolving, you shouldn't get this
method. I tested and it actually solves the problem above as well. I
suppose to be fully general we'd have to allow you to specify the logic
for this as well.
> Is it normal?
No.
> I tested with contains instead of refers and the snippet is generated
> properly. In my case, it is really a weak container.
I expect container is handled a bit differently (wrongly in this case)
because it essence it's always a derived feature, i.e., derived for
EObject.eContainer(). And in fact, I think the logic you're specifying
for this produces an inconsistency because I assume you have something
like this:
package org.example.foo
import org.eclipse.emf.ecore.ENamedElement
import org.eclipse.emf.ecore.EClass
local refers readonly volatile transient derived EProgram eProgram get{
class EProgram
contains EVariables eVariables opposite eProgram
class EVariables
container EProgram eProgram opposite eVariables
contains EVariable eVariables opposite eVariables
I.e., the container for the variable is really an (sic) EVariables, not
an EProgram. So I really don't think you should be specifying a
derived container as you have. You should define a derived reference...
And you shouldn't be extending Ecore!!!
> Thanks
Ed Merks
FUDForum. Page generated in 0.06892 seconds
