org.eclipse.equinox.p2.core.ProvisionException [message #896612] |
Thu, 19 July 2012 07:21 |
sajja Phani Messages: 26 Registered: August 2011 |
In my RCP application, I have define a product which is based on features with p2 support. I have added all the dependencies to the features --> plugins. I exported the product for Linux gtk 32 and 64 bit versions.
My development system is Ubuntu 64bit. The exported 64 bit version is running fine on my machine and another 64 bit Fedora system for update (Install New Software).
When I run the 32 bit version it is giving the org.eclipse.equinox.p2.core.ProvisionException in a window and the log says
!SESSION 2012-07-19 11:25:08.149 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_IN
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY in.expertsoftware.sampark.dashboard 1 0 2012-07-19 11:25:09.012
!MESSAGE Starting Dashboard!!
!ENTRY org.eclipse.core.net 1 0 2012-07-19 11:25:32.591
!MESSAGE System property http.proxyHost is not set but should be ....
!ENTRY org.eclipse.core.net 1 0 2012-07-19 11:25:32.594
!MESSAGE System property http.proxyPort is not set but should be 8080.
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 0 2012-07-19 11:25:38.258
!MESSAGE Unexpected error loading extension: org.eclipse.equinox.p2.metadata.repository.simpleRepository
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class org.apache.commons.httpclient.HttpClient
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientBrowseFileTransferFactory$1.sendBrowseRequest(HttpClientBrowseFileTransferFactory.java:53)
at org.eclipse.ecf.provider.filetransfer.browse.MultiProtocolFileSystemBrowserAdapter.sendBrowseRequest(MultiProtocolFileSystemBrowserAdapter.java:95)
at org.eclipse.equinox.internal.p2.transport.ecf.FileInfoReader.sendBrowseRequest(FileInfoReader.java:186)
at org.eclipse.equinox.internal.p2.transport.ecf.FileInfoReader.getRemoteFiles(FileInfoReader.java:112)
at org.eclipse.equinox.internal.p2.transport.ecf.FileInfoReader.getRemoteFile(FileInfoReader.java:128)
at org.eclipse.equinox.internal.p2.transport.ecf.FileInfoReader.getLastModified(FileInfoReader.java:133)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.getLastModified(RepositoryTransport.java:203)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:134)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:749)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:117)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:102)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82)
at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
The org.apache.commons.httpclient plugin is present in the plugins directory.
Even after setting the proxy in Network preferences it is giving the same error.
What might be the problem?
Note: The problem is with Fedora 8 32bit and working fine with Fedora 14 32bit
Sajja
[Updated on: Fri, 20 July 2012 06:10] Report message to a moderator
FUDForum. Page generated in 0.03056 seconds
