Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] JSONTexoResource, DynamicModelObject support(Texo support for JSONTexoResource, DynamicModelObject)
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #896790 is a reply to message #896604] |
Thu, 19 July 2012 19:09 |
Hi Neeraj,
No update at the moment since the blog post..., the dynamic model object is being used inside of Texo but I don't have
to many specific test cases for it. What do you want to do?
gr. Martin
On 07/19/2012 08:42 AM, Neeraj Bhusare wrote:
> Any update on the implementation of the http://wiki.eclipse.org/Texo/EMFResource? Also, any pointers/samples on the
> DynamicModelObject support. The http://wiki.eclipse.org/Texo/Texo_and_EMF states that the first implementation is
> available.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #897432 is a reply to message #897336] |
Tue, 24 July 2012 06:48 |
Hi Neeraj,
Both topics have my clear interest to have/add them (which means that it could be done within a month or so), maybe the
first works fine but this part has not been tested thoroughly. For the json emf resource the skeleton code is there but
I need to finish the implementation.
Can you ping/come back in a few weeks from now? Actually, it is no problem to just ask again every week... I am most of
the time quite busy but sometimes/often I can/will do this in between my other work.
gr. Martin
On 07/23/2012 05:57 PM, Neeraj Bhusare wrote:
> Hi Martin,
> Sorry for the delayed reply. There are two things that I need to do - 1) Dynamically creating meta-model on the server
> side. If I am not wrong, I could use the Texo dynamic model object support. 2) Something similar to the
> http://wiki.eclipse.org/Texo/EMFResource - An RCP client, Webservices and a Database.
> So far I have tried the http://wiki.eclipse.org/Texo/JSON_REST_Web_Services samples and I am looking forward to make use
> of it. However, I would like to know if you have anything planned for the "TexoJSONResource" implementation. Also, is
> there an alternative available for now.
The Netherlands
Current Time: Fri Apr 26 19:30:13 GMT 2024
Powered by FUDForum. Page generated in 0.03522 seconds
