Home » Modeling » Graphiti » creating new editor
creating new editor [message #896573] |
Thu, 19 July 2012 00:00 |
rama hana Messages: 10 Registered: July 2012 |
I have already started with graphiti refering to the tutorial. Currently I want to implement my own Graphiti editor. My graphical editor is intended for the the M-Sigma metamodel which is an extension of the Ecore metamodel.
Source code of my editor is the following:
MANIFEST.MF :
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: M-SigmaEditor
Bundle-SymbolicName: org.eclipse.graphiti.M-Sigma.Editor;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Activator: org.eclipse.graphiti.m_sigma.editor.Activator
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.graphiti;bundle-version="0.8.2",
org.eclipse.graphiti.ui;bundle-version="0.8.2",
org.eclipse.core.resources;bundle-version="3.7.101",
org.eclipse.core.runtime.source;bundle-version="3.7.0",
org.eclipse.core.runtime.compatibility.source;bundle-version="3.2.100",
org.eclipse.core.runtime.compatibility.registry.source;bundle-version="3.5.0",
org.eclipse.core.runtime.compatibility.auth.source;bundle-version="3.2.200",
org.eclipse.core.runtime.compatibility.auth;bundle-version="3.2.200",
org.eclipse.core.runtime.compatibility;bundle-version="3.2.100",
org.eclipse.ui.views.properties.tabbed;bundle-version="3.5.200",
org.eclipse.graphiti.examples.common;bundle-version="0.8.2"
Bundle-ActivationPolicy: lazy
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
pluguin.xml :
<?eclipse version="3.4"?>
<plugin>
<extension
point="org.eclipse.graphiti.ui.diagramTypes">
<diagramType
description="This is the diagram type for M-Sigma Editor"
id="org.eclipse.graphiti.M-Sigma.Editor.MSigmadiagramType"
name="M-Sigma Diagram Type"
[b]type="MSigma"[/b]>
</diagramType>
</extension>
<extension
point="org.eclipse.graphiti.ui.diagramTypeProviders">
<diagramTypeProvider
class="org.eclipse.graphiti.m_sigma.editor.MSigmaDiagramTypeProvider"
description="This is M-Sigma editor for the Graphiti Editor"
id="org.eclipse.graphiti.M-Sigma.Editor.MSigmadiagramTypeProvider"
name="M-Sigma Editor">
</diagramTypeProvider>
</extension>
</plugin>
MSigmaDiagramTypeProvider.java
package org.eclipse.graphiti.m_sigma.editor;
import org.eclipse.graphiti.dt.AbstractDiagramTypeProvider;
import org.eclipse.graphiti.dt.IDiagramTypeProvider;
public class MSigmaDiagramTypeProvider extends AbstractDiagramTypeProvider
implements IDiagramTypeProvider {
public MSigmaDiagramTypeProvider() {
super();
setFeatureProvider(new MSigmaFeatureProvider(this));
MSigmaFeatureProvider.java
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EReference;
import org.eclipse.graphiti.features.IAddFeature;
import org.eclipse.graphiti.features.ICreateFeature;
import org.eclipse.graphiti.features.context.IAddContext;
import org.eclipse.graphiti.m_sigma.features.MSigmaAddEClassFeature;
import org.eclipse.graphiti.m_sigma.features.MSigmaCreateEClassFeature;
import org.eclipse.graphiti.ui.features.DefaultFeatureProvider;
public class MSigmaFeatureProvider extends DefaultFeatureProvider {
public MSigmaFeatureProvider(IDiagramTypeProvider dtp) {
super(dtp);
// TODO Auto-generated constructor stub
public IAddFeature getAddFeature(IAddContext context) {
//is object for add request a EClass?
if (context.getNewObject() instanceof EClass) {
return new MSigmaAddEClassFeature(this);
return super.getAddFeature(context);
public ICreateFeature[] getCreateFeatures() {
return new ICreateFeature[] { new MSigmaCreateEClassFeature(this) };
MSigmaAddEClassFeature.java
package org.eclipse.graphiti.m_sigma.features;
import org.eclipse.graphiti.features.IFeatureProvider;
import org.eclipse.graphiti.features.impl.AbstractAddShapeFeature;
import org.eclipse.graphiti.mm.algorithms.GraphicsAlgorithm;
import org.eclipse.graphiti.mm.algorithms.Polyline;
import org.eclipse.graphiti.mm.algorithms.Rectangle;
import org.eclipse.graphiti.mm.algorithms.RoundedRectangle;
import org.eclipse.graphiti.mm.algorithms.Text;
import org.eclipse.graphiti.mm.algorithms.styles.Orientation;
import org.eclipse.graphiti.mm.pictograms.BoxRelativeAnchor;
import org.eclipse.graphiti.mm.pictograms.ContainerShape;
import org.eclipse.graphiti.mm.pictograms.Diagram;
import org.eclipse.graphiti.mm.pictograms.PictogramElement;
import org.eclipse.graphiti.mm.pictograms.Shape;
import org.eclipse.graphiti.services.Graphiti;
import org.eclipse.graphiti.services.IGaService;
import org.eclipse.graphiti.services.IPeCreateService;
import org.eclipse.graphiti.util.ColorConstant;
import org.eclipse.graphiti.util.IColorConstant;
public class MSigmaAddEClassFeature extends AbstractAddShapeFeature {
private static final IColorConstant CLASS_TEXT_FOREGROUND =
new ColorConstant(51, 51, 153);
private static final IColorConstant CLASS_FOREGROUND =
new ColorConstant(255, 102, 0);
private static final IColorConstant CLASS_BACKGROUND =
new ColorConstant(255, 204, 153);
public MSigmaAddEClassFeature(IFeatureProvider fp) {
super(fp);
//The method canAdd has to check the given context and therefore it decides if a business object can be added
public boolean canAdd(IAddContext context) {
// check if user wants to add a EClass
// check if user wants to add to a diagram
if (context.getTargetContainer() instanceof Diagram) {
return true;
return false;
//The method add finally has to create the pictogram structure described above and has to establish the linkage to the business object
@SuppressWarnings("deprecation")
public PictogramElement add(IAddContext context) {
EClass addedClass = (EClass) context.getNewObject();
Diagram targetDiagram = (Diagram) context.getTargetContainer();
// CONTAINER SHAPE WITH ROUNDED RECTANGLE
IPeCreateService peCreateService = Graphiti.getPeCreateService();
ContainerShape containerShape =
peCreateService.createContainerShape(targetDiagram, true);
// define a default size for the shape
int width = 100;
int height = 50;
IGaService gaService = Graphiti.getGaService();
// create and set graphics algorithm
RoundedRectangle roundedRectangle =
gaService.createRoundedRectangle(containerShape, 5, 5);
roundedRectangle.setForeground(manageColor(CLASS_FOREGROUND));
roundedRectangle.setBackground(manageColor(CLASS_BACKGROUND));
roundedRectangle.setLineWidth(2);
gaService.setLocationAndSize(roundedRectangle,
context.getX(), context.getY(), width, height);
// if added Class has no resource we add it to the resource
// of the diagram
// in a real scenario the business model would have its own resource
if (addedClass.eResource() == null) {
getDiagram().eResource().getContents().add(addedClass);
// create link and wire it
link(containerShape, addedClass);
// SHAPE WITH LINE
// create shape for line
Shape shape = peCreateService.createShape(containerShape, false);
Polyline polyline =
gaService.createPolyline(shape, new int[] { 0, 20, width, 20 });
polyline.setForeground(manageColor(CLASS_FOREGROUND));
polyline.setLineWidth(2);
// SHAPE WITH TEXT
// create shape for text
// create and set text graphics algorithm
Text text = gaService.createDefaultText(getDiagram(), shape,
addedClass.getName());
text.setForeground(manageColor(CLASS_TEXT_FOREGROUND));
text.setHorizontalAlignment(Orientation.ALIGNMENT_CENTER);
text.setVerticalAlignment(Orientation.ALIGNMENT_CENTER);
text.getFont().setBold(true);
gaService.setLocationAndSize(text, 0, 0, width, 20);
link(shape, addedClass);
// add a chopbox anchor to the shape
peCreateService.createChopboxAnchor(containerShape);
// create an additional box relative anchor at middle-right
final BoxRelativeAnchor boxAnchor =
peCreateService.createBoxRelativeAnchor(containerShape);
boxAnchor.setRelativeWidth(1.0);
boxAnchor.setRelativeHeight(0.5);
// anchor references visible rectangle instead of invisible rectangle
GraphicsAlgorithm roundedRectangle = null;
boxAnchor.setReferencedGraphicsAlgorithm(roundedRectangle);
// assign a graphics algorithm for the box relative anchor
Rectangle rectangle = gaService.createRectangle(boxAnchor);
rectangle.setFilled(true);
gaService.setLocationAndSize(rectangle, -2 * w, -w, 2 * w, 2 * w);
rectangle.setForeground(manageColor(CLASS_FOREGROUND));
rectangle.setBackground(manageColor(CLASS_BACKGROUND));
return containerShape;
MSigmaCreateEClassFeature.java
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.graphiti.examples.common.ExampleUtil;
import org.eclipse.graphiti.features.context.ICreateContext;
import org.eclipse.graphiti.features.impl.AbstractCreateFeature;
public class MSigmaCreateEClassFeature extends AbstractCreateFeature {
private static final String TITLE = "Create class";
private static final String USER_QUESTION = "Enter new class name";
public MSigmaCreateEClassFeature(IFeatureProvider fp) {
// set name and description of the creation feature
super(fp, "EClass", "Create EClass");
public boolean canCreate(ICreateContext context) {
return context.getTargetContainer() instanceof Diagram;
public Object[] create(ICreateContext context) {
// ask user for EClass name
String newClassName = ExampleUtil.askString(TITLE, USER_QUESTION, "");
if (newClassName == null || newClassName.trim().length() == 0) {
return EMPTY;
// create EClass
EClass newClass = EcoreFactory.eINSTANCE.createEClass();
// Add model element to resource.
// We add the model element to the resource of the diagram for
// simplicity's sake. Normally, a customer would use its own
// model persistence layer for storing the business model separately.
getDiagram().eResource().getContents().add(newClass);
newClass.setName(newClassName);
// do the add
addGraphicalRepresentation(context, newClass);
// return newly created business object(s)
return new Object[] { newClass };
Which seems strange, is when I have run the project, and during the creation of graphiti diagram, I didn't find the type that I have defined above ("MSigma"). There is only the types "tutorial" and "mytutorial" (type that I have created for the tutorial) as options. Hence, I couldn't create a diagram of type "MSigma". Is there any missing thing? What should I doing ?
Thanks in advance.
[Updated on: Sat, 21 July 2012 14:28] Report message to a moderator
Current Time: Mon Sep 23 23:33:48 GMT 2024
Powered by FUDForum. Page generated in 0.03807 seconds
