Eclipse configurations [message #896426] |
Wed, 18 July 2012 11:36 |
Dennis Tunaev Messages: 4 Registered: July 2012 |
I use C/C++ Eclipse 3.4.2 for linux (at work), when I trying to debug my project and use F6 key (or Step Over), the debuger anyway always entering to system files (for exemple stl_tree.h,iostream). It also jumping from function to function forward/back without any reason... why? can I correct it some way?
Thank you
[Updated on: Wed, 18 July 2012 13:31] Report message to a moderator
Re: Eclipse configurations [message #898513 is a reply to message #896712] |
Thu, 26 July 2012 13:57 |
Hi Dennis,
just to clarify. I'm afraid you ended up in the wrong forum.
The people in this forum can only answer questions around the Eclipse Process Manager project (Stardust) and we would not have been able to help with your debugger problem.
In case you have any further problems in that area, you should find the appropriate forum to get your answers as quickly as possible.
See the list of all projects here: http://www.eclipse.org/forums/
Jan
FUDForum. Page generated in 0.03346 seconds
