Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT browser not working with XULRunner 1.8.x, 1.9.x, 3.6.x, 10.x downloaded from mozilla.org(SWT browser not working with XULRunner 1.8.x, 1.9.x, 3.6.x, 10.x downloaded from mozilla.org)
SWT browser not working with XULRunner 1.8.x, 1.9.x, 3.6.x, 10.x downloaded from mozilla.org [message #896363] Wed, 18 July 2012 04:02 Go to next message
I'm using latest SWT 4.2 with an application in which I want to bundle XULRunner in order to deliver end user a portable application (our users always complain about setting MOZILLA_FIVE_HOME or other browser related issues on Linux). For this, I downloaded XULRunner from mozilla.org (h++p://ftp.mozilla.org/pub/mozilla.org/xulrunner/releases/) and passed the following jvm options:
-Dorg.eclipse.swt.browser.XULRunnerPath=xulrunner (where xulrunner folder is available in my app)
-Dorg.eclipse.swt.browser.DefaultType=mozilla
Unfortunately I receive XPCOM error when I use any of 1.9, 3.6 and 10 xullrunners. When I remove the two options, it starts correctly as it finds a proper webkitgtk installation. This is fine, but I want it to work seamlessly on any Linux distribution even without webkitgtk.
My test platforms are Ubuntu 11.04 and 12.04, Sun JVM 1.7.03 32 bit, XULRunner 32bit 1.8.x, 1.9.x, 3.6.x, 10.x.
Mohsen
[Updated on: Wed, 18 July 2012 04:07] by Moderator
Re: SWT browser do not work with XULRunner 1.8.x, 1.9.x, 3.6.x, 10.x downloaded from mozilla.org [message #896498 is a reply to message #896363] Wed, 18 July 2012 10:19 Go to previous messageGo to next message
It sounds like you're doing the right thing, though you do not have to
set the org.eclipse.swt.browser.DefaultType property if you don't
strongly care which of the native renderers gets used (WebKitGTK is
tried first, but if it's not available then the fallback to a
mozilla-based renderer happens automatically).
If you're getting an XPCOM error then it sounds like it's finding a
XULRunner. What does the error's stack look like? Does the snippet at
www.eclipse.org/swt/faq.php#printmozillapath work for you (set its
org.eclipse.swt.browser.XULRunnerPath value with System.setProperty(...))?
Grant
On 7/18/2012 4:02 AM, Mohsen Saboorian wrote:
> Thanks
> Mohsen
Re: SWT browser do not work with XULRunner 1.8.x, 1.9.x, 3.6.x, 10.x downloaded from mozilla.org [message #896510 is a reply to message #896498] Wed, 18 July 2012 11:25 Go to previous messageGo to next message
Thanks for the reply. Here is the output:
>>>Snippet creating SWT.MOZILLA-style Browser
XULRunner path: ./xulrunner/libxpcom.so
>>>This failed with the following error:
org.eclipse.swt.SWTError: XPCOM error 0x80520001
	at org.eclipse.swt.browser.Mozilla.error(Unknown Source)
	at org.eclipse.swt.browser.Mozilla.initXPCOM(Unknown Source)
	at org.eclipse.swt.browser.Mozilla.create(Unknown Source)
	at org.eclipse.swt.browser.Browser.<init>(Unknown Source)
	at DisplayMozillaVersion.main(DisplayMozillaVersion.java:14)
Snippet creating SWT.NONE-style Browser
>>>This failed too, with the following error:
	at DisplayMozillaVersion.main(DisplayMozillaVersion.java:21)
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0xb7741537, pid=5923, tid=3065842496
# JRE version: 7.0_05-b05
# Java VM: Java HotSpot(TM) Client VM (23.1-b03 mixed mode linux-x86 )
# Problematic frame:
# C  [ld-linux.so.2+0x9537]  _dl_rtld_di_serinfo+0xa17
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/mohsen/Desktop/zekr-portable/hs_err_pid5923.log
# If you would like to submit a bug report, please visit:
#   h++p://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted (core dumped)
icon14.gif  Re: SWT browser do not work with XULRunner 1.8.x, 1.9.x, 3.6.x, 10.x downloaded from mozilla.org [message #896795 is a reply to message #896498] Thu, 19 July 2012 16:14 Go to previous message
The problem resolved by specifying full path of the XULRunner after the propertye:
. I believe this is a bug, and Eclipse should also accept relative paths. Please specify this trick in SWQ FAQ page until it's resolved in future releases.
Thanks.
Previous Topic:SWT at the ARM , Linux
Next Topic:Wrong font on Eclipse Juno Editor Tabs
Current Time: Tue Nov 04 00:37:58 EST 2025
Powered by FUDForum. Page generated in 0.05566 seconds
