[SOLVED] deploy.xml and missing Associated Port [message #895663] |
Sat, 14 July 2012 11:57 |
AxA AxA Messages: 5 Registered: July 2012 |
I'm following this tutorial: (Can't insert links yet ) http***://www-inf.it-sudparis.eu/~nguyen_n/teaching_assistant/bpel/bpel_structured_activities_-_pick
And I'm having two main problems:
1) When I create the 2 "assign" actions, I'm not able (as in the screenshots presented in the tutorial) to insert my own expression. I can't write anything in the text field. Eventually, for the sake of completing the tutorial, I manually modified the .bpel file and added the expressions I needed.
2) Although all the files *.bpel, *.wsdl are in the same -bpelContent- folder, when I create the file deploy.xml (in this same folder), in the ODE deployment Editor I don't have any item in the -Associated Port- menu list. And I'm not sure how to manually edit deploy.xml
Eventually, I'm not able to complete the tutorial.
Does anybody know a solution for these issues? Thanks!
[Updated on: Sat, 14 July 2012 19:39] Report message to a moderator
FUDForum. Page generated in 0.03078 seconds
