Project Export's build logs are deleted, so it's impossible to know what went wrong [message #895488] |
Fri, 13 July 2012 09:12 |
Filip Paczyński Messages: 4 Registered: July 2012 |
I'm trying to export my scout project, the export fails, an error message such as this can be found in eclipse's log:
org.eclipse.scout.sdk.ui.wizard.AbstractWorkspaceWizard$P_PerformFinishOperation.run(AbstractWorkspaceWizard.java:131)
exception during perfoming finish on wizard page 'org.eclipse.scout.sdk.ui.internal.wizard.export.ExportScoutProjectWizard'.
with asociated stack trace:
org.eclipse.core.runtime.CoreException: could not export server war file
at org.eclipse.scout.sdk.ui.internal.extensions.export.ServerExportEntryHandler.createModule(ServerExportEntryHandler.java:54)
at org.eclipse.scout.sdk.ui.internal.wizard.export.ExportScoutProjectWizard.performFinish(ExportScoutProjectWizard.java:55)
at org.eclipse.scout.sdk.ui.wizard.AbstractWorkspaceWizard$P_PerformFinishOperation.run(AbstractWorkspaceWizard.java:121)
at org.eclipse.scout.sdk.jobs.OperationJob.run(OperationJob.java:105)
at org.eclipse.scout.sdk.jobs.AbstractWorkspaceBlockingJob.doRun(AbstractWorkspaceBlockingJob.java:61)
at org.eclipse.scout.sdk.jobs.AbstractWorkspaceBlockingJob.run(AbstractWorkspaceBlockingJob.java:39)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.core.runtime.CoreException: Compilation errors occurred during the operation. A zip file containing the build logs has been generated and placed at f:\temp\LOCALT~1\dir1092557095920430265warExportBuildDir/WEB-INF/eclipse
at org.eclipse.scout.sdk.operation.export.ExportServerWarOperation.buildServerProduct(ExportServerWarOperation.java:165)
at org.eclipse.scout.sdk.operation.export.ExportServerWarOperation.run(ExportServerWarOperation.java:91)
at org.eclipse.scout.sdk.ui.internal.extensions.export.ServerExportEntryHandler.createModule(ServerExportEntryHandler.java:50)
... 6 more
Unfortunately, the zip file mentioned in the stack trace does not exists and there is no other information concerning the failed build process to be found.
Interestingly, I can export a blank scout project just fine (but all the logs from temp are still deleted).
More interestingly, I can export the failing project through eclipse's export wizard (as an eclipse application, which is hardly useful in this case).
Best regards - Filip Paczyński
Re: Project Export's build logs are deleted, so it's impossible to know what went wrong [message #895504 is a reply to message #895488] |
Fri, 13 July 2012 10:04 |
Could you provide some more information:
- workspace
- xxx.client
- xxx.shared
- xxx.server
- xxx.ui.swt
- any other?
Did you make any changes to the product files (e.g. adding/removing some bundles)?
And the best would be a screenshot of every page in the export wizard. To answer the following questions:
- Does the export path contain any special characters?
- Which product are you trying to export?
- Which client product is included in the export?
- Do you export also a RAP server?
- Are you trying to export a war or an ear file?
Thank you
-andreas
Re: Project Export's build logs are deleted, so it's impossible to know what went wrong [message #895661 is a reply to message #895519] |
Sat, 14 July 2012 11:17 |
Thanks a lot for the information.
Bad news: I still do not know a reason for your export failure.
Better news: I can provide a way to find the export log files.
The export mechanism deletes all files in the temporary build directory without considering the result of the build. Therefore I opened Bug 385102.
I attached the patched 'org.eclipse.scout.sdk_3.8.0.201206130843' and 'org.eclipse.scout.sdk.source_3.8.0.201206130843' bundles. If you download Eclipse for Scout Developers (Juno) and replace the two bundles. You will be able to access the log directory after the export. Important is to replace the bundles with the same version and qualifier.
Let me know the progress;)
-andreas
Attachment: plugins.zip
(Size: 1.11MB, Downloaded 331 times)
Re: Project Export's build logs are deleted, so it's impossible to know what went wrong [message #895862 is a reply to message #895860] |
Mon, 16 July 2012 11:16 |
I'm using windows 7
Finally, I've worked it out.
As suspected, I've had an error in one of my .java files which was not detected by eclipse, but was detected by eclipse compiler... don't really know how it was possible. It looked like this:
@Mixins(EntityFragment.Mixin.class)
The type EntityFragment is ambiguous
EntityFragment is an inner type, defined at the same level as the annotated class. I can't see how how could that cause a problem, since there was no public or package-level type with that name anywhere.
Anyway, after fixing all 'type xxxx is ambiguous' errors the build finally succeeded.
In order to get that simple build error message I had to:
- setup a separate workspace,
- check out scout's sources,
- define run configuration,
- setup a breakpoint at ExportServerWarOperation.java:165,
- run scout in debug mode
- import my projects into debugged instance's workspace
- export project from debugged instance - failed due to PermGen space erors
- increase PermGen space & friends through run config's cmdline options,
- restart, try exporting again
- navigate to builddir in temp folder,
- extract the log files,
- search all of them for errors
Quite a lot of work to get a build error msg.
I think it would be great if export wizard could output all the errors and warnings from compiler into eclipse's log, or at least console. That would've saved so much time.
I would like to thank the community, especially Andreas, for all the help offered.
FUDForum. Page generated in 0.02998 seconds
