Re: upgrate birt 2.3.2 to birt 4.2 [message #896036 is a reply to message #895657] |
Tue, 17 July 2012 02:44 |
What is the open source project? Is it downloadable? The Viewer is a
Java Web application that makes use of the report engine.
Jason
On 7/14/2012 5:01 AM, maatrihard maatallah wrote:
> firstly thank you sir for your response
> I'm not sure, because the application is open source and I roves all
> plugins in one folder "plugins" and viewservlets.jar.
> my new question: what is the difference between (Report engine and
> webviewer)for this upgrade
> thank your again sir
Re: upgrate birt 2.3.2 to birt 4.2 [message #897400 is a reply to message #897260] |
Tue, 24 July 2012 01:41 |
If you have access to the libs and plugins for the 2.3.2 you should be
able to upgrade by just using the birt 4.2 libs and removing the 2.3.2
plugins. The 4.2 runtime is a simple POJO based runtime and only
requires the set of jars in the runtime/reportengine/lib directory of
the runtime download. The only issue is that you need to remove the
config.setBIRTHome from your code. BIRT 4.2 also has an OSGi runtime
download if you would rather use it. If you decide to do this you could
just replace the libs and plugins from the 4.2 OSGi runtime download.
Jason
On 7/23/2012 8:44 AM, maatrihard maatallah wrote:
> hello this app isn't downloadable
Re: upgrate birt 2.3.2 to birt 4.2 [message #897628 is a reply to message #897509] |
Tue, 24 July 2012 19:56 |
OSGi is the framework that eclipse runs on. It is used to dynamically
load plugins that the designer uses.
Jason
On 7/24/2012 6:32 AM, maatrihard maatallah wrote:
> thank you jason
> it's clear
> Q: What is OSGI and why it is used with birt
> thank you
FUDForum. Page generated in 0.03928 seconds
