Re: Key Bindings in RAP [message #895071 is a reply to message #895055] |
Wed, 11 July 2012 15:18 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Stefan,
probably the problem is in the modifier SHIFT, which triggers the
uppercase. Could you try with CTRL instead?
Best,
Ivan
On 7/11/2012 5:50 PM, Stefan Ruzitschka wrote:
> Hey Folks,
> I would like to use the key binding feature in RAP 1.5 with global keys:
> display.setData(RWT.ACTIVE_KEYS, new String[] { "SHIFT+W",
> "SHIFT+A", "SHIFT+S", "SHIFT+D" });
> display.addFilter(SWT.KeyDown, new Listener()
> @Override
> public void handleEvent(final Event event)
> System.out.println(event.keyCode + "" + event.stateMask);
> But none of the active key combinations work. It would be nice to have
> a list of keys oder key combinations that work.
> The goal is to have 4 keys/combinations to move s.th. around. And they
> should be global and browser independent.
> Can anyone help?
> Greetings
> Stefan Ruzitschka
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Key Bindings in RAP [message #895248 is a reply to message #895055] |
Thu, 12 July 2012 09:15 |
Tim Buschtoens Messages: 396 Registered: July 2009 |
Hi.
This should definitely work. Please file a report in the RAP BugZilla.
Also, which exact Version of RAP are you using?
Greetings,
Tim
Am 11.07.2012 16:50, schrieb Stefan Ruzitschka:
> Hey Folks,
> @Override
> But none of the active key combinations work. It would be nice to have a
> Can anyone help?
> Greetings
> Stefan Ruzitschka
Tim Buschtöns
Re: Key Bindings in RAP [message #895255 is a reply to message #895248] |
Thu, 12 July 2012 09:27 |
Wait a sec, it works fine for me.
Did you possibly forget the main loop in your application?
Greetings,
Tim
Am 12.07.2012 11:15, schrieb Tim Buschtöns:
> Hi.
> Greetings,
> Tim
>> Hey Folks,
>> @Override
>> Can anyone help?
>> Greetings
>> Stefan Ruzitschka
Tim Buschtöns
FUDForum. Page generated in 0.03170 seconds
