Home » Eclipse Projects » Linux Tools Project » error logged from debug core(error while running opencv file)
error logged from debug core [message #894965] Wed, 11 July 2012 05:23 Go to next message
after running opencv file error occur
"error logged from debug core"
java.io.IOException: read error
at org.eclipse.cdt.utils.spawner.SpawnerInputStream.read0(Native Method)
at org.eclipse.cdt.utils.spawner.SpawnerInputStream.read(SpawnerInputStream.java:66)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:273)
at java.io.BufferedInputStream.read(BufferedInputStream.java:334)
at java.io.FilterInputStream.read(FilterInputStream.java:107)
at org.eclipse.debug.internal.core.OutputStreamMonitor.read(OutputStreamMonitor.java:144)
at org.eclipse.debug.internal.core.OutputStreamMonitor.access$1(OutputStreamMonitor.java:134)
at org.eclipse.debug.internal.core.OutputStreamMonitor$1.run(OutputStreamMonitor.java:207)
at java.lang.Thread.run(Thread.java:679)
Re: error logged from debug core [message #898609 is a reply to message #894965] Thu, 26 July 2012 17:13 Go to previous message
Can you elaborate on what you were doing that had to with any of the Linux Tools project plug-ins?
If this is a C/C++ debugger issue, you should post to the CDT forum instead.
Otherwise, please provide more details on what you were doing and how you set up your project.
Previous Topic:Errors while building Juno from source
Next Topic:Eclipse package dependency in run-time
Current Time: Wed Sep 10 05:18:58 EDT 2025
Powered by FUDForum. Page generated in 0.31690 seconds
