Home » Eclipse Projects » JFace » Table Viewer - Composite as Cell Editor(Table Viewer - Custom Cell Editor)
Table Viewer - Composite as Cell Editor [message #894704] Tue, 10 July 2012 04:16 Go to next message
I want to add a composite(which contains multiple check boxes) to a table cell. I am able to do so using TableEditor. But there are issues related to Memory Leaks, so I want to add this composite to a table cell using CellEditor. Could anyone guide me in implementing such CellEditor? Also each cell in a column may contain different number of check boxes.
Ashish Rawat
Re: Table Viewer - Composite as Cell Editor [message #896900 is a reply to message #894704] Fri, 20 July 2012 07:00 Go to previous messageGo to next message
Hi Ashish,
Were you able to get any solution for this issue. Even I am facing this, have used a label inside the TableEditor , and this makes the entire table slow. Is it something I am doing wrong.
Is there any work around?
Could you please let me know
Re: Table Viewer - Composite as Cell Editor [message #896903 is a reply to message #896900] Fri, 20 July 2012 07:21 Go to previous message
Hi guys,
take a look at this article, it could help you
http://www.eclipse.org/articles/Article-Table-viewer/table_viewer.html
Previous Topic:TreeViewer EditElement Question
Next Topic:TextEditor with editable syntax highlighting
Current Time: Sun Oct 26 15:18:39 EDT 2025
Powered by FUDForum. Page generated in 0.04625 seconds
