Re: Copy and Paste from clipboard in EMF [message #894545 is a reply to message #894523] |
Mon, 09 July 2012 14:48 |
becks m Messages: 59 Registered: June 2012 |
Member |
Unfortunately, I don't use the generated editor, I want to make use of it in another ui plugin.
should I consider emf to do that , or I use ordinary eclipse copy and paste
Ed Merks wrote on Mon, 09 July 2012 10:00The generated editor supports copy and paste. It just uses a local
clipboard, i.e., local to the one editor. You can copy and things like
CopyCommand and PasteCommand.
On 09/07/2012 3:48 PM, becks m wrote:
> Hi again,
> Is there copy and paste from clipboard in EMF ?
> if yes, then where to look for ?
Re: Copy and Paste from clipboard in EMF [message #894611 is a reply to message #894545] |
Mon, 09 July 2012 19:50 |
Ed Merks Messages: 33141 Registered: July 2009 |
If you aren't using EMF's command framework, you'll probably want to use
something ordinary.
> paste
>> like CopyCommand and PasteCommand.
>> > Hi again,
Ed Merks
FUDForum. Page generated in 0.04265 seconds
