Home » Eclipse Projects » Mylyn » Error on New Bugzilla Repository in Juno(Error on New Bugzilla Repository in Juno)
Error on New Bugzilla Repository in Juno [message #894202] Sat, 07 July 2012 11:11 Go to next message
Environment:
Juno
Bugzilla 4.2.1
When adding a new Bugzilla task repository I am able to validate the credentials successfully, but when finishing I get
Error updating repository configuration
No products found in repository configuration. Ensure credentials are valid
This is the same task repository being connected to from Eclipse 3.7.2 and have verified that can still connect, etc from 3.7.2
Re: Error on New Bugzilla Repository in Juno [message #895554 is a reply to message #894202] Fri, 13 July 2012 10:04 Go to previous messageGo to next message
That could indicate a problem with storing of credentials. Do you have a
version of the org.eclipse.core.runtime.compatibility.auth bundle in the
plugins folder of your Eclipse installation?
Steffen
Mike Love wrote:
> Environment:
> Juno
> Bugzilla 4.2.1
> valid
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Error on New Bugzilla Repository in Juno [message #896665 is a reply to message #895554] Thu, 19 July 2012 06:34 Go to previous messageGo to next message
Steffen, Thanks for the response
I don't have org.eclipse.core.runtime.compatibility.auth in the eclipse installation
Should I add this manually?
Re: Error on New Bugzilla Repository in Juno [message #896978 is a reply to message #896665] Fri, 20 July 2012 12:08 Go to previous message
You could try adding the bundle to your plugins folder. You can download it
here:
download.eclipse.org/mylyn/snapshots/compatibility/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.200.v20110110.jar
You may need to start eclipse with -clean afterwards to pick up the new
bundle.
HTH,
Steffen
> installation
Steffen Pingel
Principal Software Engineer, Eclipse Mylyn Tasks Lead
http://tasktop.com
Previous Topic:Generating toc in pdf via WikiText and xslfo and fop
Next Topic:Media wiki Internal Links connecting Problem
Current Time: Sun Nov 09 14:12:14 EST 2025
Powered by FUDForum. Page generated in 0.06205 seconds
