Using a different configuration gives a NullPointerException [message #893687] |
Thu, 05 July 2012 05:29  |
I am just using NatTable and I like it so far. I am working through the tutorials and I get an null pointer exception when I use a different configuration (autoconfigure = false).
I even used the default table (example) the reproduce the problem:
natTable = new NatTable(parent, false);
natTable.addConfiguration(new HeaderMenuConfiguration(natTable));
natTable.configure();
When I use that the content in the body is not being displayed. If I click on a table cell in the body I get the following NullPointerException:
at net.sourceforge.nattable.ui.matcher.CellPainterMouseEventMatcher.matches(CellPainterMouseEventMatcher.java:45)
at net.sourceforge.nattable.ui.binding.UiBindingRegistry.getDragMode(UiBindingRegistry.java:47)
at net.sourceforge.nattable.ui.mode.ConfigurableModeEventHandler.mouseDown(ConfigurableModeEventHandler.java:49)
at net.sourceforge.nattable.ui.mode.ModeSupport.mouseDown(ModeSupport.java:85)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:192)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
The parent is an org.eclipse.swt.widgets.Composite.
I am building an Eclipse E4 RCP application.
Does anybody know what is wrong?
Can it have something to do with Eclipse E4 RCP?
[Updated on: Thu, 05 July 2012 05:41] by Moderator
FUDForum. Page generated in 0.16764 seconds
