Home » Archived » BIRT » how to change export file name
how to change export file name [message #893683] Thu, 05 July 2012 05:09 Go to next message
birt 2.3.x
<context-param>
		<param-name>BIRT_FILENAME_GENERATOR_CLASS</param-name>
		<param-value>com.link.report.FilenameGenerator</param-value>
	</context-param>
package jetsennet.jnmp.report;
import java.util.Date;
import java.util.Map;
import org.eclipse.birt.report.utility.filename.IFilenameGenerator;
public class FilenameGenerator implements IFilenameGenerator
	 * default report file name
	public static final String DEFAULT_FILENAME = "report";
	public String getFilename(String [b]fileName[/b], String extension,
	        String outputType, Map options)
		System.out.println(baseName);
		return makeFileName(baseName, extension);
	 * Makes a filename using the target extension from the options.
	 * @param fileName
	 *            file name which extension must be replaced
	 * @return file name with replaced extension
	public static String makeFileName(String fileName, String extensionName)
		String baseName = fileName;
		if (baseName == null || baseName.trim().length() <= 0)
			baseName = DEFAULT_FILENAME;
		// check whether the file name contains non US-ASCII characters
		for (int i = 0; i < baseName.length(); i++)
			char c = baseName.charAt(i);
			// char is from 0-127
			if (c < 0x00 || c >= 0x80)
				break;
		// append extension name
		if (extensionName != null && extensionName.length() > 0)
			baseName += (new Date()).toString() + "." + extensionName; //$NON-NLS-1$
		return baseName;
I'd like to use the follow code, but it is unusable!
<birt:viewer id="birtViewer" reportDesign="reports/alarmeventstatisticsnew.rptdesign"
pattern="frameset"
format="HTML"
isHostPage = "true">
<birt:param name="baseName" value="myexportfile"/>
</birt:viewer>
how to change baseName, or how to pass parameter to baseName?
[Updated on: Thu, 05 July 2012 06:13] by Moderator
Re: how to change export file name [message #893807 is a reply to message #893683] Thu, 05 July 2012 10:25 Go to previous messageGo to next message
I assume you read through this post?
http://birtworld.blogspot.com/2008/09/naming-exported-files-from-birt.html
baseName is passed in and in your case should be
I am not certain 2.3.x implemented the filename generator extension.
Did this context parameter already exist in your web.xml?
> <context-param>
> </context-param>
Or did you add it?
Jason
On 7/5/2012 5:09 AM, smith link wrote:
> birt 2.3.x
> <context-param>
> </context-param>
> public String getFilename(String baseName, String extension,
> * * @param fileName
> extensionName)
> break;
> //$NON-NLS-1$
> return baseName;
> pattern="frameset"
> format="HTML"
> <birt:param name="baseName" value="ok"/>
> </birt:viewer>
Re: how to change export file name [message #894381 is a reply to message #893807] Sun, 08 July 2012 22:02 Go to previous message
Thanks Jason.
Previous Topic:Adhoc Reporting in Open Source BIRT
Next Topic:Error in Localization?
Current Time: Sun Aug 17 03:25:08 EDT 2025
Powered by FUDForum. Page generated in 0.04595 seconds
