Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 1.5 with Java 7(RAP with Java 7)
RAP 1.5 with Java 7 [message #891751] Mon, 25 June 2012 14:50 Go to next message
Is RAP 1.5 RC3 tested with Java 7? I am doing research to make sure that the framework works on Java 7 but I cannot find a confirmation anywhere in the Internet.
Ronald
Re: RAP 1.5 with Java 7 [message #891821 is a reply to message #891751] Tue, 26 June 2012 03:10 Go to previous messageGo to next message
Ronald,
RAP requires Java 1.5. In recent releases of the JDK, they tried hard to
stay compatible with previous versions. To spot potential
incompatibilities, I'd recommend to read the JDK migration guide for 1.7
(if there is any).
In addition, compiling RAP against 1.7 and running the test suite might
also reveal incompatibilities.
HTH
Rüdiger
On 25.06.2012 20:50, Ronald So wrote:
> in the Internet.
> Ronald
Rüdiger Herrmann
http://codeaffine.com
Re: RAP 1.5 with Java 7 [message #892630 is a reply to message #891821] Thu, 28 June 2012 16:02 Go to previous messageGo to next message
Thanks Rüdiger. We will find cycles to test and post our results up here.
At the meantime, does anyone of you who are building and running RAP in Java 7?
Ronald
Re: RAP 1.5 with Java 7 [message #895534 is a reply to message #891821] Fri, 13 July 2012 08:54 Go to previous messageGo to next message
Hi!
I think it would be a good idea to mention it needs 1.5 somewhere: In release notes or in the getting started guide.
It's probably obvious to many people, but to me it wasn't Smile
E.g. the demos don't run under 1.7.
[Updated on: Fri, 13 July 2012 08:55] by Moderator
Re: RAP 1.5 with Java 7 [message #895546 is a reply to message #895534] Fri, 13 July 2012 09:52 Go to previous messageGo to next message
Seb,
please see my comments below.
Rüdiger
On 13.07.2012 14:54, Seb L wrote:
> Hi!
> I think it would be a good idea to mention that somewhere: In release
As all RAP artifacts are OSGi bundles they carry the minimum required
execution environment in their manifest.
But I agree that I might be worth documenting this elsewhere.
> It's probably obvious to many people, but to me it wasn't :)
Please let us know what exactly isn't working, I doubt that Java 1.7
isn't backwards compatible.
What demos do you refer to?
What JDK do you compile against?
What JRE are you running on?
What exactly is the error that you see?
A bug report [1] with detailed information to reproduce the issue would
be great.
[1] http://www.eclipse.org/rap/bugs/
> Regards
Rüdiger Herrmann
Re: RAP 1.5 with Java 7 [message #895584 is a reply to message #895546] Fri, 13 July 2012 12:53 Go to previous message
Sure, there you go:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=385074
Previous Topic:Combo has some strange behaviour with arrow keys
Next Topic:RAP 1.5 RC3 in iOS zooming problem
Current Time: Fri Oct 31 23:26:32 EDT 2025
Powered by FUDForum. Page generated in 0.05974 seconds
