Load Time Weaving [message #890572] |
Fri, 22 June 2012 11:34 |
Hello Guys,
I'm currently trying to apply load time weaving to my project.
I created a simple AspectJ project in Eclipse and I'm able to weave it during compile time successful.
I created two packages. One is called "examples.AspectJ" where you can find my java class. The second package is called "examples.AspectJ.aspect" where you can find my aspect.
Additionally, I added the aop.xml file in the Project/AspectJ-Properties and I inserted "-Daj.weaving.verbose=true -Dorg.aspectj.weaver.showWeaveInfo=true -javaagent:c:/aspectj1.6/lib/aspectjweaver.jar -Xbootclasspath/a:C:/aspectj1.6/lib/aspectjrt.jar;C:/Users/hpet/Documents/aspect.jar" to the VM arguments of my run configuration.
When I'm trying to run altogether, I got the following error message:
[AppClassLoader@1473a2e] info AspectJ Weaver Version 1.6.12 built on Tuesday Oct 18, 2011 at 17:52:06 GMT
[AppClassLoader@1473a2e] info register classloader sun.misc.Launcher$AppClassLoader@1473a2e
[AppClassLoader@1473a2e] info using configuration file:/C:/Users/hpet/Documents/aspect.jar!/META-INF/aop.xml
[AppClassLoader@1473a2e] info register aspect examples.AspectJ.aspect.AspectClass
[AppClassLoader@1473a2e] debug weaving 'examples.AspectJ.JavaClass'
[AppClassLoader@1473a2e] info processing reweavable type examples.AspectJ.JavaClass: examples\AspectJ\JavaClass.java
[AppClassLoader@1473a2e] info successfully verified type examples.AspectJ.aspect.AspectClass exists. Originates from examples\AspectJ\aspect\C:\workspace\AspectJExample\src\examples\AspectJ\aspect\AspectClass.aj
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(int))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:13) advised by after advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:38)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(int))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:13) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:60)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(int))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:13) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:55)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(int))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:13) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:42)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(double))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:14) advised by after advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:38)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(double))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:14) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:60)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(double))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:14) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:55)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(double))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:14) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:42)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(int, java.lang.String))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:15) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:60)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(int, java.lang.String))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:15) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:55)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(int, double))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:16) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:60)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method1(int, double))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:16) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:55)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(void examples.AspectJ.JavaClass.method2(int, java.lang.String))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:17) advised by before advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:64)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(int examples.AspectJ.JavaClass.test(int))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:24) advised by afterReturning advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:51)
[AppClassLoader@1473a2e] weaveinfo Join point 'method-call(int examples.AspectJ.JavaClass.test(int))' in Type 'examples.AspectJ.JavaClass' (JavaClass.java:24) advised by around advice from 'examples.AspectJ.aspect.AspectClass' (AspectClass.aj:68)
[AppClassLoader@1473a2e] debug generating class 'examples.AspectJ.JavaClass$AjcClosure1'
Aspect Execution Code BEFORE...
Exception in thread "main" java.lang.NoClassDefFoundError: examples/AspectJ/JavaClass
at examples.AspectJ.aspect.AspectClass.ajc$before$examples_AspectJ_aspect_AspectClass$2$3b6e9b9c(AspectClass.aj:44)
at examples.AspectJ.JavaClass.main(JavaClass.java:13)
I'm guessing that there's some dependency between the aspect and the java class and the aspect is not able to find the java class.
Thanks for your help.
FUDForum. Page generated in 0.04267 seconds
