Re: can not deactivate handler (only toolbar) [message #890353 is a reply to message #890326] |
Fri, 22 June 2012 06:29 |
Hello yuta,
Maybe you could try this:
// Update the enabled state of the ToolBar controls.
IWorkbench workbench = PlatformUI.getWorkbench();
if (workbench != null) {
IEvaluationService evaluationService = (IEvaluationService) PlatformUI
.getWorkbench().getService(IEvaluationService.class);
evaluationService
.requestEvaluation("org.eclipse.ui.workbenchWindow.isPerspectiveOpen");
The evaluationService.requestEvaluation("link for the Property of the defined propertytester") method enforces the PropertyTesters to make a test again.
Tell us/me if that does not work, because there are also other solutions I can image for you.
And, sorry to bad English.
Don´t worry about that, as long as we can understand you. The main thing is that you can get ahead with your work.
Simon
[Updated on: Fri, 22 June 2012 07:17] Report message to a moderator
Re: can not deactivate handler (only toolbar) [message #892820 is a reply to message #891448] |
Fri, 29 June 2012 21:56 |
yuta kobayashi wrote on Mon, 25 June 2012 04:15
(in IPerspectiveListener4#perspectiveOpened, does not work well)
This depends on what you actually want to achieve with the listener.
You did not mention, what your aim is, when the IPerspectiveListener3#perspectiveOpened listener is invoked.
But the IPerspectiveListener3#perspectiveOpened is only invoked if a perpective is added to the org.eclipse.ui.internal.WorkbenchPage and not if it is already opened and the user activates the perspective.
@see WorkbenchPage#addPerspective(Perspective persp)
@see WorkbenchPage#createPerspective(PerspectiveDescriptor desc, boolean notify)
Only those two methods invoke the firePerspectiveOpened method of the org.eclipse.ui.internal.WorkbenchWindow
However, I can not understand why "re-evaluation" is necessary for only toolbar.
eclipse's bug?
I think the performance of the Client would lack, if the PropertyTester would be tested all the time.
But that would be necessary, if you want the handler´s state to be updated out of the box, because the toolbar is always visible to the user.
Concerning a menu the state is evaluated, when the user opens the menu, but the toolbar is kind of "always opened" and there is not user action to be done in order to see the toolbaritem.
Got it?
So the developer is reponsible to update the state by using the IEvaluationService, like Paul Webster explained.
Is that correct Paul?
Simon
FUDForum. Page generated in 0.03517 seconds
