Home » Eclipse Projects » Remote Application Platform (RAP) » Recall of IEntryPoint.createUI() after saving editor
Recall of IEntryPoint.createUI() after saving editor [message #118516] Fri, 16 January 2009 10:48 Go to next message
Bogdan B. is currently offline Bogdan B.Friend
Member
I added the ActionFactory.SAVE action to the toolbar in my RAP_1.2M4
application using my extension of ActionBarAdvisor (exactly how it is done
in the demo application that comes with RAP). The icon is shown, the
enabling works fine, but when I save, then the .createUI() method of my
extension of IEntryPoint (MyEntryPoint in the stack trace) is called again
although it shouldn't. This call produces the NPE shown below.
My question is: why is it called again?
Shouldn't it be called only once when the application starts? I checked
the demo and it is indeed only called once and not on every saving the
changes from an editor.
So what am I doing wrong? Is there something I still should configure?
at
org.eclipse.jface.action.StatusLineManager$1.setCanceled(Sta tusLineManager.java:188)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:354)
at
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2445)
at
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:273)
at
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:252)
at
org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:147)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1354)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:3185)
at
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:3198)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:75)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:500 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:580)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:497)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:449)
at
org.eclipse.swt.internal.widgets.UntypedEventAdapter.dispatc hEvent(UntypedEventAdapter.java:365)
at
org.eclipse.swt.internal.widgets.UntypedEventAdapter.widgetS elected(UntypedEventAdapter.java:82)
at
org.eclipse.swt.events.SelectionEvent.dispatchToObserver(Sel ectionEvent.java:176)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.jav a:44)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.ja va:117)
at org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.jav a:157)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.readAndDispa tch(RWTLifeCycle.java:241)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :685)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2388)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2347)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:425)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:333)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:408)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at com.centrasite.workbench.MyEntryPoint.createUI(MyEntryPoint. java:17)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:595)
Re: Recall of IEntryPoint.createUI() after saving editor [message #118532 is a reply to message #118516] Mon, 19 January 2009 09:56 Go to previous messageGo to next message
Rüdiger Herrmann is currently offline Rüdiger HerrmannFriend
I can't see where MyEntryPoint is called *again*. Apparently there
is a difference between your code and the demo application code.
Bogdan B. wrote:
> done in the demo application that comes with RAP). The icon is shown,
> the enabling works fine, but when I save, then the .createUI() method of
> my extension of IEntryPoint (MyEntryPoint in the stack trace) is called
> again although it shouldn't. This call produces the NPE shown below.
> My question is: why is it called again? Shouldn't it be called only once
> when the application starts? I checked the demo and it is indeed only
> called once and not on every saving the changes from an editor.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Recall of IEntryPoint.createUI() after saving editor [message #118547 is a reply to message #118532] Mon, 19 January 2009 10:37 Go to previous messageGo to next message
Member
Hi, and thanks for the answer. Maybe I wasn't too clear, I shall explain
it again:
The demo application works fine, its entry point is DemoWorkbench, and its
createUI() is called only once when the demo application starts, and NOT
when I save an editor (as it should be).
The problem occurs only in my application. The NPE corresponding to the
posted stack trace is thrown when I save the changes made in an editor
from my application, not the demo application. MyEntrypoint is the
implementation of IEntryPointin in my application (as DemoWorkbench is the
implementation of IEntryPoint in the demo application). What I am saying
is that .createUI() shouldn't be called here at all, it has been already
called when my application first started (which is the only place it
should be called).
And I was asking whether you have any ideas of what could cause a second
call of recreating the UI when I save an editor.
Re: Recall of IEntryPoint.createUI() after saving editor [message #118603 is a reply to message #118547] Mon, 19 January 2009 11:27 Go to previous messageGo to next message
> it again:
> its createUI() is called only once when the demo application starts, and
> NOT when I save an editor (as it should be).
> the implementation of IEntryPoint in the demo application). What I am
> saying is that .createUI() shouldn't be called here at all, it has been
> already called when my application first started (which is the only
> place it should be called).
I am not sure if I got you.
MyEntryPoint is always contained in the stack trace because it is
one of the first things being called and only ever returned from if
the session terminates. This is why you will see it in each and
every stack trace. It is like the main method of a "normal" Java
application.
Re: Recall of IEntryPoint.createUI() after saving editor [message #118672 is a reply to message #118603] Mon, 19 January 2009 12:52 Go to previous messageGo to next message
Member
> application.
Yes, you are right, sorry.
Anyway, I found the problem: on saving the changes made in an editor, the
following will be called (first line of my stack trace):
But in my application I have overriden
WorkbenchWindowAdvisor.createWindowContents() to not create a menu and a
status line (as it would be created by default, and as the demo
application does), because I don't need them.
Which means that StatusLineManager.createControl(Composite, int) will
never be invoked in my application, which leaves
StatusLineManager.statusLine null, which produces the NPE when the saving
reaches the line 188 of StatusLineManager: "if (statusLine.isDisposed())
To sustain this, if I add the following into
WorkbenchWindowAdvisor.createWindowContents():
getWindowConfigurer().getPresentationFactory().createStatusL ineControl(
((WorkbenchWindow)getWindowConfigurer().getWindow()).getStat usLineManager(),
shell);
than it works fine.
But why should I create a status line if I don't need it? Wouldn't be
better if you check if the statusline is not null before you check if it
has been disposed?
Re: Recall of IEntryPoint.createUI() after saving editor [message #118692 is a reply to message #118672] Mon, 19 January 2009 13:34 Go to previous messageGo to next message
> has been disposed?
The code from StatusLineManager originally belongs to JFace and was
adopted for RAP. Feel free to file a bug for Platform / JFace:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform
Re: Recall of IEntryPoint.createUI() after saving editor [message #118768 is a reply to message #118692] Mon, 19 January 2009 16:24 Go to previous messageGo to next message
Member
Thank you again for the trouble, Rüdiger!
Re: Recall of IEntryPoint.createUI() after saving editor [message #119216 is a reply to message #118672] Thu, 22 January 2009 12:35 Go to previous message
Matthias Maar is currently offline Matthias MaarFriend
Hi Bogdan,
as the JavaDoc for WorkbenchWindowAdvisor.createWindowContents() states,
you can control the visibility of some default workbench items by using
the setShow* methods. So simply adding
getWindowConfigurer().setShowStatusLine(false) in the preWindowOpen()
method of your overridden WorkbenchWindowAdvisor class effectively hides
the status bar. Overriding the createWindowContents() is most often not
necessary and error prone.
Matthias
>> MyEntryPoint is always contained in the stack trace because it is one
>> of the first things being called and only ever returned from if the
>> session terminates. This is why you will see it in each and every
>> stack trace. It is like the main method of a "normal" Java application.
> the following will be called (first line of my stack trace):
> saving reaches the line 188 of StatusLineManager: "if
> (statusLine.isDisposed()) {".
> shell);
> than it works fine.
> has been disposed?
Previous Topic:KeyListener and VerifyText on Text can't co-exist ?
Next Topic:Building on M4
Current Time: Sat Jun 03 06:19:13 GMT 2023
Powered by FUDForum. Page generated in 0.01738 seconds
