Home » Modeling » EMF » XML file reading using ecore and java program
XML file reading using ecore and java program [message #888496] Mon, 18 June 2012 03:39 Go to next message
I am reading an XML file using an ecore model and a java program. I have a field ABC-Id in my xml file. For that I have an EAttribute ABC-Id. If I have an EAttribute ABC-Id, then cannot create a genmodel. Error comes -> The name ABC-Id is not well formed.
I need to keep 'ABC-Id' as it is in XML and need to read that file using an ecore and a java program. Can someone propose me an apprach to solve this issue?
Thanks in advance
K
[Updated on: Mon, 18 June 2012 04:07] by Moderator
Re: XML file reading using ecore and java program [message #888530 is a reply to message #888496] Mon, 18 June 2012 04:44 Go to previous message
TX. I could solve the issue !
Previous Topic:Allowing custom extension to my model
Next Topic:[CDO/Teneo/Hibernate] java.lang.IllegalArgumentException: Invalid type: java.math.BigDecimal
Current Time: Sun Sep 21 17:44:24 EDT 2025
Powered by FUDForum. Page generated in 0.03274 seconds
