Re: ant execution on linux [message #118820 is a reply to message #117980] |
Fri, 30 November 2007 14:09 |
DuWayne Morris Messages: 36 Registered: July 2009 |
Member |
What is happening here is that the session JVM is dying, probably right
when it starts. The InactiveProcessException happens after a timeout to
indicate this. We have one defect scheduled to be fixed in 4.5 that might
be the case you are seeing:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=200194
In this defect, the auto-build job may be causing the session runner to
exit on account of missing classes needed to run. Unfortunately, there is
nothing that you would be able to do to work-around that issue until it is
fixed.
Whenever errors happen like this, it is a good idea to kill any zombie
java processes that might be lingering and re-start the agent controller
(AC).
There has been some discussion of random problems associated with having
eclipse open with the same workspace that is being used by an ant script.
So, you may want to avoid this.
You also may want to try the IBM 1.5 JVM, just to see if there is a
difference in behavior. Also, what version of RedHat are you running and
with how much physical memory?
Hope this helps, even though not a solid answer.
DuWayne
Re: ant execution on linux [message #120390 is a reply to message #118820] |
Wed, 09 January 2008 16:35 |
Nick Young Messages: 16 Registered: July 2009 |
Hi DuWayne, sorry for the delay in responding, I'll try out the suggestions
you have below.
In the meantime if it helps, we are running this on Redhat 4 which has 4gb
of physical memory, some 2gb being free to me at this time. I have however
also observed similar behaviour on other platforms...
Nick
"DuWayne Morris" <dmorris@us.ibm.com> wrote in message
news:82068fb6caed0722a79ac0c4e5f0af3c$1@www.eclipse.org...
> fixed.
> (AC).
> DuWayne
FUDForum. Page generated in 0.02995 seconds
