Home » Eclipse Projects » Remote Application Platform (RAP) » Store Initial Parameters from web.xml
Store Initial Parameters from web.xml [message #117589] |
Tue, 06 January 2009 10:55 |
Originally posted by: benjamin.wolff.web.de
when starting my application i want to read some values from the web.xml an store them with application scope.
my question is, what would be suitable to use? i need a store which doesn't need a ui-session because i want to
call it when starting the app, would using the PluginPreferenceStore be a proper way to do that?
moreover i'd like to ask, whether the Activator start() method is a common way to 'initialize' the plugin with
values from the web.xml? the values don't have to be stored persistent, restarting the app will cause a reload,
that's a wanted behaviour.
thx in common.
greetings,
ben
Re: Store Initial Parameters from web.xml [message #118299 is a reply to message #117589] |
Mon, 12 January 2009 13:29 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Ben W. wrote:
Just out of curiosity, how do you *read* values from the web.xml?
From what I know, the web.xml is not intended to be read.
Use a pref store only if the values should be persisted.
Activator#start() is a good place to do application-wide initialization.
> thx in common.
> greetings,
> ben
Re: Store Initial Parameters from web.xml [message #118317 is a reply to message #118299] |
Mon, 12 January 2009 15:02 |
Hi Rüdiger,
with reading the web.xml i mean extracting some parameters. i contribute some environment variables, e.g. to make the connection to the database.
i couldn't manage to use a JNDI DataSource so far with RAP so i still connect manually with the DriverManager#getConnection().
now i'm using the Activator#getPluginPreferences() to store non-ui relevant application wide values and for the workbench (session) scope i use
Activator#getPreferenceStore(). actually i'm using utility classes which provide static getter and setter for the values, but the underlying containers
are those mentioned above. works quit well for now.
by the way, if there are any tutorials or howtos about using a JNDI DataSource with RAP (to be more specific: using the servletbridge) i'd be grateful for
some pointers. i'd like to define the DataSource completely in the web.xml, without touching the context.xml oder server.xml of the underlying servlet container.
i couldn't figure out how to do this until now, nevertheless i'm already using the BridgeServlet classloader "hack" to access the web.xml.
greetings,
ben
Rüdiger Herrmann schrieb:
> Ben W. wrote:
>> Hi,
> Just out of curiosity, how do you *read* values from the web.xml? From
>> thx in common.
>> greetings,
>> ben
Re: Store Initial Parameters from web.xml [message #118335 is a reply to message #118317] |
Mon, 12 January 2009 15:36 |
Ben W. wrote:
> Hi Rüdiger,
> use
> containers
> be grateful for
I am not aware of such a tutorial...
> greetings,
> ben
>> Ben W. wrote:
>>> Hi,
>>> thx in common.
>>> greetings,
>>> ben
Current Time: Sat Apr 27 03:41:15 GMT 2024
Powered by FUDForum. Page generated in 0.03041 seconds
