Home » Newcomers » Newcomers » MinGW GCC is not functioning(Missing library)
MinGW GCC is not functioning [message #886211] Thu, 14 June 2012 08:52 Go to next message
I open a new C++ Hello World Project and try to build and run it. The build goes without errors, but when I run it, there is no output to the console. When I run the executable file manually, it complains: The program can't start because libgcc_s_dw2-1.dll is missing from your computer. Try reinstalling the program to fix this program.
I have recently installed MinGW in the default directory; which Eclipse recognizes when I open a new C++ project. When I choose the Microsoft Visual C++ toolchain which I also have installed, it works properly. Do you suggest to just use this last toolchain then, or is there an easy way to fix this error?
Re: MinGW GCC is not functioning [message #886272 is a reply to message #886211] Thu, 14 June 2012 11:34 Go to previous message
The sticky posts at the top of this forum informed you that C/C++
questions should be asked in the Eclipse CDT forum.
Previous Topic:Eclipse Running
Next Topic: IBM rational in Eclipse
Current Time: Fri Nov 07 02:49:53 EST 2025
Powered by FUDForum. Page generated in 0.09218 seconds
