Home » Modeling » Epsilon » EGL/EOL java code
EGL/EOL java code [message #885946] Wed, 13 June 2012 19:01 Go to next message
Hi All,
Can some please pass me any small example (or link to) of generating Java code from the domain models using EGL/EOL.
Arnaldo
Re: EGL/EOL java code [message #886072 is a reply to message #885946] Thu, 14 June 2012 03:34 Go to previous messageGo to next message
Hi Arnaldo,
I'm not sure which domain models you're referring to :-/.
Regardless, here's an example for using EGL to generate HTML code from a model. Generating Java code is pretty much the same, except you might want to register an appropriate formatter:
http://www.eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.examples.egldoc
Did that help?
Antonio
Re: EGL/EOL java code [message #886094 is a reply to message #886072] Thu, 14 June 2012 04:27 Go to previous messageGo to next message
Hi Antonio
Thanks, but I am referring to XMI based models drawn on EMF/GMF editor, as processing of generating code from domain specific modeling language.
Also, how to of register an appropriate formatter such for JAVA.
Any guide would help a lot.
Arnaldo
Re: EGL/EOL java code [message #886661 is a reply to message #886072] Fri, 15 June 2012 07:36 Go to previous messageGo to next message
I have found some example on the use of formatter to genarate EGL template based Java code
 var f = new Native("org.eclipse.epsilon.egl.formatter.language.JavaFormatter");
 var t = TemplateFactory.load("generate_some_java.egl");
 t.setFormatter(f);
 t.generate("formatted.java");
However, would it be possible to have look at some EGL template and generated Java code, to understand better on its use. This would help including me all the newcomers to utilize EOL/EGL for model-to-text transformation.
Arnaldo
Re: EGL/EOL java code [message #890159 is a reply to message #886661] Thu, 21 June 2012 06:10 Go to previous messageGo to next message
Hi All,
Can someone please provide me with an example/snippet of EGL template, specified for generating Java code.
Arnaldo
Re: EGL/EOL java code [message #890236 is a reply to message #890159] Thu, 21 June 2012 10:40 Go to previous messageGo to next message
Any EGL template is sufficient:
  var className = "MyClass";
 * Header of [%= className %]
class [%= className %] {
  // Add methods
This might be a bit boring as it just generates an empty class (with a static name), so you'd need to expand it with more useful stuff.
[Updated on: Thu, 21 June 2012 10:40] by Moderator
Re: EGL/EOL java code [message #890466 is a reply to message #890236] Fri, 22 June 2012 07:13 Go to previous message
Thanks Maarten
Previous Topic:Strange Model Artifacts
Next Topic:EVL validation fixes are not usable when having multiple EVL files
Current Time: Mon Nov 03 09:37:23 EST 2025
Powered by FUDForum. Page generated in 0.21591 seconds
