Home » Eclipse Projects » Remote Application Platform (RAP) » toolbar rendering issue.
toolbar rendering issue. [message #117505] Mon, 05 January 2009 11:44 Go to next message
My application shows and hides workbench toolbar items when the
perspective changes. When switching among the 3 perspectives, the toolbar
will render correctly serveral times and then it will show up in the
middle of the window instead of the left edge. It acts like there is an
invisible toolbar there because I cannot manually move it. The toolitems
are implemented as action sets.
Has anyone else run into this issue and if so, how did you fix it?
Re: toolbar rendering issue. [message #117684 is a reply to message #117505] Tue, 06 January 2009 15:59 Go to previous messageGo to next message
Scott,
you could try the same in an RCP application. If it works there,
feel free to file a bugzilla.
Cheers
Rüdiger
> toolbar will render correctly serveral times and then it will show up in
> the middle of the window instead of the left edge. It acts like there
> is an invisible toolbar there because I cannot manually move it. The
> toolitems are implemented as action sets.
> Thanks
Re: toolbar rendering issue. [message #117858 is a reply to message #117684] Wed, 07 January 2009 09:21 Go to previous message
The RCP version of our application show the toolbars correctly. I added a
bug to bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=260255
Rüdiger Herrmann wrote:
> Scott,
> Cheers
> Rüdiger
>> Thanks
Previous Topic:SingleSourcing Localization
Next Topic:how to avoid to reload flash when switched among TabItems
Current Time: Sun Nov 09 09:03:20 EST 2025
Powered by FUDForum. Page generated in 0.03005 seconds
