Re: Some text in charts are not anti-aliased [message #885916 is a reply to message #885889] |
Wed, 13 June 2012 21:22 |
Thanks for the update. What output format are you using for the chart?
Jason
On 6/13/2012 4:09 PM, Shannon Hardt wrote:
> UPDATE: The behavior described above was for the report viewer in
> eclipse. When I deployed to tomcat and rendered the report using the web
> viewer, all chart text was anti-aliased correctly. Looks like the
> behavior is specific to the viewer within eclipse.
Re: Some text in charts are not anti-aliased [message #886755 is a reply to message #885916] |
Fri, 15 June 2012 15:21 |
Shannon Hardt Messages: 4 Registered: June 2012 |
I have tried SVG, JPG, PNG, and BMP as output formats for the chart.
When I render the report with output format PNG in web viewer, it also renders the chart with text that is not anti-aliased. However, when I render it with SVG in the web viewer, the fonts are anti-aliased. Same behavior on export to PDF - with SVG output format, fonts look good - otherwise, they do not.
Perhaps the browser/pdf viewer knows how to render the fonts properly for SVG-defined images, but when the report engine generates a binary image file it does not?
Also, I am running on Mac OS X 10.7.3.
[Updated on: Fri, 15 June 2012 15:49] Report message to a moderator
FUDForum. Page generated in 0.03258 seconds
