Re: [Teneo] Annotation in ecore model (foreign key and annotation for options) [message #117393 is a reply to message #117325] |
Wed, 09 April 2008 05:11 |
Hi Torsten,
Yes correct, I have thought about adding a properties page which allows you to set properties for an
ecore file or a separate property file in the same directory as the ecore file but had not have time
to add this functionality.
You can also programmatically create the mapping through the HbHelper.INSTANCE.generateMapping(..)
method, so if you write a class with a main method which creates a new hbm file then you can easily
test it.
gr. Martin
Torsten Link wrote:
> Martin Taal wrote:
> Hi Martin,
> Thank you for your fast reply.
> The reason for setting the options as annotations is for testing only.
> When I generate the mapping file by rightclicking the ecore model it
> will not know the options which I set in the programm code.
>> Hi Torsten,
>> The following annotation will store the association as a bag (so without
>> index column): @OneToMany(indexed=false)
>> See also here:
> http://www.elver.org/hibernate/hibernate_relations.html#Mapp ing+non-indexed+relations
>> The following annotation will set the foreign key join column:
>> @JoinColumn(name="library_id")
>> The elver.org website contains many examples of annotations, for example:
>> http://www.elver.org/hibernate/ejb3_examples.html
>> Regarding the options, these are all global options so I am not sure what
>> you mean set as annotations? Why would you for example set the sql escape
>> character by association?
>> You can set these global options by passing them to the datastore.
>> gr. Martin
>> Torsten Link wrote:
>>> Hi,
>>> 1. FOREIGN_KEY Annotation:
>>> I Have the following Model.
>>> A Class Library contains many Books. Containment Reference.
>>> The foreignKey in the book table is library_id.
>>> Now I would like to set an Annotation in the ecore which defines that
>>> the Relation is a bag not a list and the foreignKey Column name is
>>> 'library_id'.
>>> I tried the following Annotation (I tried also many more ...) but it
>>> does not work.
>>> <eStructuralFeatures
>>> xsi:type="ecore:EReference"
>>> name="books"
>>> upperBound="-1"
>>> eType="#//IBook"
>>> containment="true">
>>> <eAnnotations source="teneo.jpa">
>>> <details
>>> key="appinfo"
>>> value="@OneToMany(mappedBy=library_id)"/>
>>> </eAnnotations>
>>> </eStructuralFeatures>
>>> 2. Could I set the following Options also as Annotation?
>>> PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG
>>> PersistenceOptions.SQL_NAME_ESCAPE_CHARACTER
>>> PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH
>>> PersistenceOptions.ALWAYS_VERSION
>>> or how could I define it for each relation
>>> Thank you in advance
>>> Torsten Link
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Annotation in ecore model (foreign key and annotation for options) [message #616129 is a reply to message #117325] |
Hi Torsten,
test it.
gr. Martin
Torsten Link wrote:
> Martin Taal wrote:
> Hi Martin,
>> Hi Torsten,
>> See also here:
>> gr. Martin
>> Torsten Link wrote:
>>> Hi,
>>> 'library_id'.
>>> does not work.
>>> name="books"
>>> upperBound="-1"
>>> eType="#//IBook"
>>> containment="true">
>>> <details
>>> key="appinfo"
>>> </eAnnotations>
>>> Torsten Link
The Netherlands
FUDForum. Page generated in 0.04510 seconds
