Home » Eclipse Projects » GEF » GEF or SWT-Designer (newbie question)
GEF or SWT-Designer (newbie question) [message #116918] Tue, 10 February 2004 21:10 Go to next message
Originally posted by: svenkat.asu.edu
I wanted to create an application that provides a graphical editor, where
users can choose shapes from a tool bar and place it on the editing
area...somewhat similar to a UML editing program. Can I use SWT-Designer
(which claims to be a wonderful GUI creator) or do I use GEF as a
starting-point?
Thanks!
Prabhu.
Re: GEF or SWT-Designer (newbie question) [message #116931 is a reply to message #116918] Tue, 10 February 2004 23:55 Go to previous messageGo to next message
Originally posted by: brian.fernandes.codito.com
How complex is your editing process ? If it's just dragging a few items onto
a canvas, then I think SWT-Designer should suffice.
But I'm sure your editor gets more complex than that - if it's like a UML
diagram, then I'd suggest you use GEF ... a GUI and a Graphical Editor are
not the same thing.
All the best,
Brian.
"Prabhu" <svenkat@asu.edu> wrote in message news:c0c2ps$1ba$1@eclipse.org...
> starting-point?
> Thanks!
> Prabhu.
Re: GEF or SWT-Designer (newbie question) [message #117295 is a reply to message #116918] Thu, 12 February 2004 04:57 Go to previous message
Originally posted by: eostroukhov.hotmail.com
SWT designer (I guess, you refer to the plugin by Instantiations) is used to
create dialogs - i.e. place controls on the form, tie events and generate
Java code to use this dialog in your application. In most cases such dialogs
will be static at the runtime - they are not to be edited by users. Users
only input data in the dialog fields.
GEF is a framework for creating visual editors - i.e. UML editor, SWT
designer, WYISWYG report editor etc. It allows you to create palette window,
accept user commands, etc.
I guess, you need GEF :)
Eugene
> starting-point?
> Thanks!
> Prabhu.
Previous Topic:emf/gef commands
Next Topic:Routing without intersecting figures
Current Time: Sun Nov 09 17:19:43 EST 2025
Powered by FUDForum. Page generated in 0.03658 seconds
