Home » Newcomers » Newcomers » Cannot connect to the internet in Eclipse..using a proxy(Cannot connect to the internet in Eclipse..using a proxy)
Cannot connect to the internet in Eclipse..using a proxy [message #883193] Thu, 07 June 2012 22:40 Go to next message
Hi All,
I cannot connect to the internet through Eclipse Indigo 3.7.2. I cannot install plug-ins or can update the software. I have proxy which I configured under Network Preferences in General. I also made changes in the Java settings in Control Panel. I also installed Firefox. Set-up all the proxy settings under there and in the Web Browser settings for Eclipse checked Firefox. I can get on the net using Firefox without any issues. I am using Windows XP. The following is the error log-
Some sites could not be found. See the error log for more detail.
Unable to connect to repository download.eclipse.org/technology/epp/packages/indigo/SR1/content.xml
Connection timed out: connect
Unable to connect to repository beust.com/content.xml
Unable to connect to repository download.eclipse.org/eclipse/updates/3.7/compositeContent.xml
Unable to connect to repository download.eclipse.org/technology/epp/packages/indigo/content.xml
Unable to connect to repository download.eclipse.org/mylyn/releases/indigo/compositeContent.xml
Unable to connect to repository download.eclipse.org/webtools/repository/indigo/content.xml
Unable to connect to repository beust.com/eclipse/content.xml
Unable to connect to repository download.eclipse.org/releases/indigo/content.xml
Unable to connect to repository testng.org/content.xml
Anybody please help
Re: Cannot connect to the internet in Eclipse..using a proxy [message #883194 is a reply to message #883193] Thu, 07 June 2012 22:41 Go to previous messageGo to next message
all have http but I removed it in the post as it is not allowing me to do so
Re: Cannot connect to the internet in Eclipse..using a proxy [message #883463 is a reply to message #883193] Fri, 08 June 2012 11:28 Go to previous messageGo to next message
The proxy settings are definitely the culprits, since none of the contacted sites seem to work.
I would double-check the proxy settings.
icon8.gif  Re: Cannot connect to the internet in Eclipse..using a proxy [message #883484 is a reply to message #883463] Fri, 08 June 2012 12:30 Go to previous message
I have the same problem. I even had my employer put me on unrestricted access on the proxy server so I'd know that wasn't an issue.
Unable to read repository at hxxp://download.eclipse.org/releases/indigo/201109230900/.
hxxp://download.eclipse.org/releases/indigo/201109230900/ is not a valid repository location.
Unable to read repository at hxxp://download.eclipse.org/eclipse/updates/3.7.
hxxp://download.eclipse.org/eclipse/updates/3.7 is not a valid repository location.
Unable to read repository at hxxp://download.eclipse.org/releases/indigo.
hxxp://download.eclipse.org/releases/indigo is not a valid repository location.
I HAVE to get around this ASAP! Can the content.jar files be manually downloaded from somewhere?
--FJP
Previous Topic:Move Shell behind a view
Next Topic:Hello,
Current Time: Tue Sep 23 19:26:30 EDT 2025
Powered by FUDForum. Page generated in 0.07497 seconds
